Torquefreaks ka-t build
- torquefreaks
1993 240sx base model no abs or hicas. No carpet or trim behind the rear seats. Started of with a rebuilt s14 ka and 600$ ebay turbo kit. Bought DIYPNP j64 megasquirt kit and got it running on that and started noob tuning it. Long story short, to much timing and blew the ring landings off on cyl #3 60psi compression remained. Now onto my new setup, first time building a short block FOR MYSELF haha.
87.5mm wiesco pistons 9.1
k1 h beam rods
arp head studs
96lb delphi inj
vw cop
diypnp
hx40
full race mani
clutch suggestions please?
k1 h beam rods
arp head studs
96lb delphi inj
vw cop
diypnp
hx40
full race mani
- street_240sx
Re: Torquefreaks ka-t build
Competition white bunny setup. Whats your power goals? Any head work?
03 evo8 gsr: stroker 2.3
I second the white bunny setup! extrmely reasonably priced and best bang for the buck in my opinion.
Do you have all those components already or is that your wish list of parts?
MY BUILD THREAD
viewtopic.php?t=47246&postdays=0&postorder=asc&start=0
Stock bore size is 89 mm. I'm assuming you meant 89.5 mm.torquefreak wrote:87.5mm wiesco pistons 9.1
howdy. good stuff. just wanted to add that Holset very specifically calls out the maximum allowable rotation of the CHRA which you have exceeded. i dont know what it is off hand but it might be worth getting your feed/drain holes more perpendicular. it may also just be an over precaution. interested to see how this thing spools on your car. ive got a lil ole hy35.
- Kfred
Who engineered that #1 cylinder coil/wire setup? Looks awesome.
RIP Nate(480sx)...
- torquefreaks
I did to check the timing with a timing light on the initial megasquirt start up.Kfred wrote:Who engineered that #1 cylinder coil/wire setup? Looks awesome.
this has since been fixed on the old t3 and the holset hasnt been mounted to be clocked yetsdaigle240 wrote:howdy. good stuff. just wanted to add that Holset very specifically calls out the maximum allowable rotation of the CHRA which you have exceeded. i dont know what it is off hand but it might be worth getting your feed/drain holes more perpendicular. it may also just be an over precaution. interested to see how this thing spools on your car. ive got a lil ole hy35.
you are correct.adamky wrote:Stock bore size is 89 mm. I'm assuming you meant 89.5 mm.torquefreak wrote:87.5mm wiesco pistons 9.1
I already have everything, waiting on the machine shop.2FAS240 wrote:I second the white bunny setup! extrmely reasonably priced and best bang for the buck in my opinion.
No head work yet, shooting for 500-600hpstreet_240sx wrote:Competition white bunny setup. Whats your power goals? Any head work?
- street_240sx
With that power goal, I'd suggest some head work
- torquefreaks
What kind of head work would you suggest?
port match & 3 angle vj on stock valves
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
- aaronlee97
Might also want to consider some cams as well. Either Kelford 272s or something in that range.
As for the clutch, I'd suggest going with an RB25 flywheel and 350z clutch. It's not as expensive, but you can get a stage 3 350z clutch that supports over 500tq easily.
- torquefreaks
- torquefreaks
So i've made more progress, but im waiting on my .63ar housing to be machined and finish installing the water meth injection. Picked up another head to start porting.
I had to.. haha
I had to.. haha
Looking dope.
- torquefreaks
Yea I am getting pretty stoked! I have been following your build for years and it gave me a lot of motivation to do this. Also digging the Swedish ka-t as well as many other but those two definitely stick out to me. I am very interesting in learning more about this "corn" but any fuel like that has to be ordered by the drum on this small island. What exactly are you running when you refer to corn?
- aaronlee97
E85. They call it corn because it's ethanol made from corn. Most guys don't run it unless there's a pump station around them somewhere, but it hold lots of potential. I really like how clean your setup is. I wish that I had the time and place to do the same thing, but unfortunately I have had to make things work where I'm at. Keep the updates coming!
- torquefreaks
So its just the new flex fuel all the new vehicles are calling for? I wish we had one of those pumps around here!
Yes, flex fuel is e85/corn. If they make e85 from sugarcane, I will start to call it rum because that is what it is. E85 is mash with gas added to it. You can make ethanol but need to denaturalize it by 2%. Basically not make it digestible.
- torquefreaks
It would be interesting to see your timing map
Send me your email address and I will send you my tune.
- aaronlee97
I'd like to be able to run E85 one of these days. I'll probably switch to MSPNP at that time though.
Tune sent.
- torquefreaks
You should consider the universal ms2 or even ms3 over the PNP. I was originally concerned about all the wiring but I wish now that I just went with the ms2 from the beginning. I sold the diypnp last week and just ordered the ms2 with map daddy.aaronlee97 wrote:I'd like to be able to run E85 one of these days. I'll probably switch to MSPNP at that time though.
Thanks supa I will take a look this evening!
Higher boost regions are not fine tuned. Probably up to 25psi it is smooth. I think I have a drastic spot around 6k around 25psi. It dumps fuel really quick. I haven't looked into to this yet to see what is the cause. Possible fuel starvation I believe.
Everything's looking great. Keep up the good work.
Hey man, build looks great What is your water/meth setup like? I'm interested in doing my own.
Ooh also on your K1 rods, how did you torque the caps?
- torquefreaks
airman wrote:Hey man, build looks great What is your water/meth setup like? I'm interested in doing my own.
The water/meth setup up is just the aem kit for boosted engines it has its own controller, pump, tank, alarm led and tube with injector with 3 different options for nozzle size.
For the rods I think it was either 45 or 55 ftlbs and 55 degrees additional I will have to verify when I get home.
I think for the timing map I will try and find a stock ignition map and then retard 1 degree per psi
I bet you 1 degree per psi is plenty modest - give 0.75 degrees per psi a shot. I ran close to 0.5 degrees on my old setup with 93 octane.
And cool, those are pretty easy to come across. And good, I'm glad you used the angle method I think I did mine to 30ft-lb + 55°.
- torquefreaks
frustration level is rising to the max! been trying to set the timing for the last week but the timing light is so dim that I cant set the timing and it was never dim before and I cant figure out why. seems no one has had this issue on google either!
- torquefreaks
Few updates and a few of my other projects on the go..
Brother in law
last but not least..(let me know if it works)
https://www.facebook.com/photo.php?v=10153379461978475
Brother in law
