Duron's $$$ at Work
duncan351
KA-T.org Featured Ride
Duron's $$$ at Work
Post by duncan351 » Fri Mar 06, 2015 10:11 pm
After many years I finally was impressed with ProEFI enough to take the financial plung and convert the S14 to E85. Hoping to joint the 800hp club in the near future. I spoke to alot of the high powered S14 and discovered a common problem with fuel starvation after a using the factory tank. I wanted to only use the factory tank without getting to far outside factory parameters. Here are pics of my fuel setup using the Power Hungry Performance Hat and making the two Walbor 450 pumps fit in the tank. More to come just been busy with work.
843whp @ 40psi
761/596 Tq 33psi 6766
http://www.enginerebuild.net
Re: Duron's $$$ at Work
Post by supakat » Sat Mar 07, 2015 12:50 am
Nice coils. These 450lph Wally's are good. No issues. You should be more than able to reach your goal. What did you do with the motor? I know you broke it down recently.
duncan351
Post by duncan351 » Sat Mar 07, 2015 7:42 am
popped a head gasket due to using roll loc pads to clean the surface so many times the head was actually wavy. Had to machine .011 off. I was tired of popping head gaskets on pump gas every now and then over the years and finally decided to convert the car to E85 along with Z32 tranny and drop my gears with upgraded axles and hubs. Just decided to do everything at once and never look back.
843whp @ 40psi
Post by supakat » Sat Mar 07, 2015 12:42 pm
True. Best upgrades I did was MS Standalone and z32 gearbox. Just make sure to get Mazworx kit. Besides forged bottom and 12mm studs, did you go 10.5:1 cr? You will love the corn especially when the price drops. I paid $2.14/gal last night.
Greaser
Master of Knowledge
Post by Greaser » Mon Mar 09, 2015 7:28 am
shoulda gone vq coils Holy **** i have another s14 valve cover in wrinkle red ready for you too!
mattheripper
Post by mattheripper » Fri Mar 13, 2015 12:10 am
^I want that..
R32 KA24DET HE341 MEGASQUIRT DIYPNP S13 suspension 18x10/12
Click it >>>> viewtopic.php?t=56032
Post by street_240sx » Fri Mar 13, 2015 3:44 pm
Good to know vq coils could work. I like my ls1 coil packs. Im still excited to go vq trans :)
rn240sx
Post by rn240sx » Tue Apr 07, 2015 6:12 pm
duncan351 wrote:After many years I finally was impressed with ProEFI enough to take the financial plung and convert the S14 to E85.
Have you tunned yet..?? How much timing are you pulling back per PSI..?? I do hear that E85 loves timing, just not sure how much it actually likes or how much it can really handle...
98 240sx ka-t (Fully Built, Bullseye 60-1 turbo, 10psi, Emanage Blue)
2014 Hyundai Genesis Coupe 2.0T (daily driver, stock for now .... )
06 Suzuki Boulevard S40
2015 Hyundai Santa Fe 2.0T (Wife's Daily)
duncan351
Post by duncan351 » Tue Apr 07, 2015 6:17 pm
Had some ignition issues with the ProEFI and the CAS trigger wheel. Ordered a new one and will install it to try to resolve issue. Will report back once the issue is resolved.
843whp @ 40psi
duncan351
843whp @ 40psi
flip240
Post by flip240 » Mon May 04, 2015 8:47 am
Looking very nice Duron! Hope it works out for you!
My setup: KA24DE-T
Post by Turbo24sxt » Mon May 18, 2015 5:51 pm
This Pile done yet man?
duncan351
Post by duncan351 » Mon May 18, 2015 7:49 pm
No but getting closer. I made some changes to the setup and if all goes well I'm a couple of weeks from starting it and getting back on the road then comes tuning.
843whp @ 40psi
DrEaMeR_VaNg
Post by DrEaMeR_VaNg » Wed May 27, 2015 9:55 pm
I'm glad to see the OG guys on this topic!
I need to get my KA-T running. :(
Nonetheless I'm looking forward to the progress!
Kouki.Love.
duncan351
Post by duncan351 » Sat Aug 01, 2015 3:40 pm
Car is back up and running but going back apart due to stock HG just couldn't handle the power past 650whp but here are some updated pics. Engine bay got cleaned up alot!
Old setup
New setup
843whp @ 40psi
Greaser
Master of Knowledge
Post by Greaser » Mon Aug 10, 2015 7:33 am
you know you can run a s13 distributor without the guts right?
what coils are those?
wheres some dyno graphs nigga.....
duncan351
Post by duncan351 » Sun Sep 06, 2015 9:01 pm
What better time to build my high compression motor with the custom pistons. Now this motor should make a little extra power.
843whp @ 40psi
Post by adamky » Sun Sep 06, 2015 9:41 pm
Oh hell yes! I'd love to have an intake manifold like that instead of my Xcessive one. Couple of questions:
1. What pistons are those? 11:1 CR?
2. What head studs will you be using on this motor? Same 11mm L19 with time serts again? I've got to pull my motor to figure out why my compression is so low and it did so poorly on a leak down test. I'm considering doing the 11mm L19s with time serts or having the head and block drilled and tapped to use the 12mm RB26 head studs.
3. Where did you get those little aluminum pieces (circled) to mount the fuel line to the bottom of the Walbro and on the fuel sock?
BTW, thanks for taking the time to explain a few things about the fuel setup the other day. I'm on the right track now. I just need to figure out what's wrong with this d@mn motor and get it fixed so I can start throwing parts on and boosting.
s14fiend
Post by s14fiend » Sun Sep 06, 2015 11:36 pm
Looking good..... are you gonna be running staged injection? What injector size?
Any specs or contact info for the intake manifold flange?
duncan351
Post by duncan351 » Mon Sep 07, 2015 11:37 am
adamky wrote:Oh hell yes! I'd love to have an intake manifold like that instead of my Xcessive one. Couple of questions:
The pistons are some custom pistons I had made by Wiseco 10.5:1 compression, running New 11mm L19 head studs with Time certs again(This is a new block). The aluminum pieces I bought from Powerhouse racing. You just have to ask for them.
As for the fuel injectors, I''m running Bosch 2000cc injectors. The secondaries, I am going to weld them up. I bought this intake from a fellow member here year ago and finally going to use it.
843whp @ 40psi
turbo2nr
Post by turbo2nr » Wed Sep 09, 2015 4:22 am
YES! HIGH COMP ka-t . I plan on doing this as well next year. I want to do 11:1.
Cant wait to see new numbers.
R.i.p. 97 s14
96 s14 ka-t
duncan351
Post by duncan351 » Sun Oct 18, 2015 8:10 pm
So that baller intake manifold didn't fit for crap on stock engine mounts. A good friend of mine is modifying the intake for me now. Meanwhile I had to relocate the fuse box and fabricated my own washer fluid reservoir.
843whp @ 40psi
duncan351
Post by duncan351 » Thu Oct 22, 2015 4:32 pm
Finished up a few things on the car today since it was slow around the shop today.
Battery Relocation to trunk complete.
Completed the additional condenser fan when A/C is on with a different oil cooler that I want to try out.
843whp @ 40psi
cham
Post by cham » Sun Oct 25, 2015 6:34 am
The batt is secure
duncan351
Post by duncan351 » Sat Nov 14, 2015 9:33 pm
Its amazing what an intake manifold and high compression can do.... 684hp @ 33 psi with stock intake and over the counter Weisco pistons. I had a few bugs so had to cut the tuning short but stopped here for now.
843whp @ 40psi
cham
Post by cham » Sat Nov 14, 2015 10:44 pm
Good work. Plenty of power.
duncan351
Post by duncan351 » Wed Dec 02, 2015 9:03 pm
Here are some Engine Bay pics finished. My TPS sensor is reversed and to reverse the signal to the computer I switched the polarity by changing the power and ground signals and it worked however the voltage value constantly is changing which would make you logically think the tps is physically moving but it honestly doesn't seem like it is. I have also lock tight the throttle plate stopper but it still changes. I have also done a sweep slowly to make sure the TPS is working properly and it does sweep evenly. This is also the 2nd TPS because I thought it was a bad Tps but same thing. Is there a nissan tps that work reverse without having to be modified?
843whp @ 40psi
Post by adamky » Wed Dec 02, 2015 9:32 pm
Looking good, brother. I had the same issue with the TPS sensor on that same throttle body. I also tried reversing it and it didn't work correctly. My solution was to break out the Dremel, make a little hole, and then mount it "upside down"...
It has worked perfectly like that for over 5 years. I think I looked at the possibility of taking apart the throttle body and reversing everything and it either seemed like too much work.... or possibly there was another issue that I saw with doing that. It's been so long that I really don't remember the exact reason. It was either laziness or something... more... technical...?!? :cool:
duncan351
Post by duncan351 » Wed Dec 02, 2015 9:47 pm
adamky, its guys like you and a few others why I stay on this forum. I really wish more members would get back involved in this forom Great info, and a simple fix that I just never thought to do. Great creativity! :bowdown:
Now as soon as Kedbmx gets done with my ignition coil bracket I can turn the boost up some more and get more tuning done. I'm sure he will get it done. I'm just excited to get back on the dyno to finish tuning the car.
843whp @ 40psi
Post by adamky » Wed Dec 02, 2015 11:17 pm
You helped me when I had questions about the Powerhouse Racing fuel hat. I'm glad that I could return the favor and help you out a little this time.
