"NASTYKA" (BUILD THREAD)
Re: "NASTYKA" (BUILD THREAD)
Post by supakat »
Video is set to private.
EmphasisElite
Post by EmphasisElite »
Try it now
EmphasisElite
Posting pics of body/first paint
ka7
Post by ka7 »
how much timing are you running?
Turnstyles
Post by Turnstyles »
I used to be in Alamo, I was the guy in the Kermit the frog green s13, you probably seen me, im on the east coast now in maryland
KA24E SOHC swaggin on haters
Post by supakat »
For the tach issue click Basic Settings --》Tach Output. Change the speed to Normal and burn.
EmphasisElite
Both settings have already been tried. And neither work.
iamxchris
Post by iamxchris »
Super nice build man, it'll be cool if you produced more of those intake manifold .
Also what coilpacks are you running?
jokertechz
Post by jokertechz »
Did you degree the cams at all? And what it your timing? I am also running bc 272 cams NA and it bogs at 1500-2000rpms while cruising but if get on it the rpms increase just fine
EmphasisElite
We had some issues at the track over the last few weeks. I have not had a lot of time to get the car to the dyno.
I finally broke the car in. We have exceeded 1000 miles and over 30hours of run time. So it was time to start turning the boost up. First jump was to 25lbs we have a very stable 12.3 afr value through the rpm band. ON the street the car was blowing through 1st gear on 275's, 2nd gear was controllable but we have aggressive tire spin top end. Third was the money gear. There is nothing like seeing your speedo bury itself as you're half way through third gear. Top of third we have a little wheel spin. I'll post abit more later as of now we are a little over 31psi of boost with 100octane out of the s400sx. We saw our first bit of knock at 26 to 28 psi on 91 pump gas. Some very interesting things happened when I was finally able to bring the boost to 30. But as I said before I'll post more info later this week as we fix the issues
nissan240sx
Post by nissan240sx »
cant wait to see numbers
1991 black 240sx R.I.P
1991 grey 240sx R.I.P
1991 240sx sold
1991 bmw e30 current
Post by street_240sx »
Hey my buddy just saw your car on base. He owns a 1jz 240sx
EmphasisElite
Yea I'm an instructor on base... I'm looking to get guys from base together sometime so more to follow, next time stop me I'd you want I love showing off the KA
Post by adamky »
This build is amazing. I can't believe the power that you were able to get from plain ole' 91oct pump.
EmphasisElite
Thanks man and it boils down to make the air pump more efficient first then throw boost/cfm's at it to increase the power curves that are already there... It hit 700+whp on 91 w/ water meth but we decided to pull some timing and de tune it to 630-680.
nissan240sx
Hey man any updates on this
1991 240sx sold
EmphasisElite
Yea it's all tuned up and running strong!! When the 315/30/18 Hoosiers get warm it's a beast!!
maniac240sx_7
Post by maniac240sx_7 »
nice build!! super sexy!!
240in
nissan240sx
They call me nasty lmao!!! Ridiculousness reference
1991 240sx sold
