2nd time around
cham
Re: 2nd time around
Post by cham »
Did you wire the Dakota digital to your tach or your speed sensor?
Re: 2nd time around
Post by adamky »
Speed sensor
cham
Re: 2nd time around
Post by cham »
Ok. About to put my mojo on it
cham
Re: 2nd time around
Post by cham »
Well. Since the new turbo I've been hitting 25psi on a 44mm tial with 2 springs that make right at 20psi. About to take the smaller spring out and run a boost controller. Hooked up air to the wg. It's opening properly
cham
Re: 2nd time around
Post by cham »
Well the car is running decent. Put some new 275's in the rear and It doesn't break loose anymore. The only problem I'm having is starter issues with this z32 trans kit. I'm using the z32 side mount car quest starters. I've tried 4 of them. The car starts fine but after driving around I guess the starter gets hot and they drag the next time you try and crank it. Let the car sit for a while and it fires up like a new starter. I've added a ground to the starter and it didn't help. I'll be pulling the adapter plate and have it machined to use the stock ka starter
fishmando2
Re: 2nd time around
Post by fishmando2 »
Do you have the contact info for Kedbmx? I would love to switch to these Honda coil-packs using his harness.
tuzzio
Re: 2nd time around
Post by tuzzio »
I've had the same issue with my WG, where you just have to run a lighter spring. Seemed to me like 2/3 of desired boost = spring pressure.
example, my target boost was 18, so I put the 11 or 12 pound spring in. I do run a MBC though.
Also, I think jegs/summit makes relatively universal starter heat blankets.
cham
Re: 2nd time around
Post by cham »
Inspired engineering is the name of his LED light company. Located in Florida. He does custom lights for jeeps and other jeep mods. Number is 1-305 814 5331
Iwannadrivemycar
Re: 2nd time around
Post by Iwannadrivemycar »
I assume you are using an AEM wiring harness?
If so could i get a pic of how you wired it to the 4 pin plug on the distributor?
Thank you.
cham
Re: 2nd time around
Post by cham »
3 pin for honda k coils. They are oem denso. 12v, ground and trigger.
Iwannadrivemycar
Re: 2nd time around
I was asking about the wiring from the aem ems4 to the stock distributor.
cham
Re: 2nd time around
Post by cham »
Factory harness plugs into the aem v2 behind the passenger kick panel and is a direct replacement for the factory ecu. It's plug and play for my year car.
cham
Re: 2nd time around
Post by cham »
No special harness needed. Just have to wire in any extra sensors you want to add to monitor whatever you want.
Re: 2nd time around
Hey Cham, glad to see you around. Keep up the good work.
cham
Re: 2nd time around
Post by cham »
