2nd time around
Re: 2nd time around
Did you wire the Dakota digital to your tach or your speed sensor?
Re: 2nd time around
Speed sensor
Re: 2nd time around
Ok. About to put my mojo on it
Re: 2nd time around
Well. Since the new turbo I've been hitting 25psi on a 44mm tial with 2 springs that make right at 20psi. About to take the smaller spring out and run a boost controller. Hooked up air to the wg. It's opening properly
Re: 2nd time around
Well the car is running decent. Put some new 275's in the rear and It doesn't break loose anymore. The only problem I'm having is starter issues with this z32 trans kit. I'm using the z32 side mount car quest starters. I've tried 4 of them. The car starts fine but after driving around I guess the starter gets hot and they drag the next time you try and crank it. Let the car sit for a while and it fires up like a new starter. I've added a ground to the starter and it didn't help. I'll be pulling the adapter plate and have it machined to use the stock ka starter
Re: 2nd time around
Do you have the contact info for Kedbmx? I would love to switch to these Honda coil-packs using his harness.
Re: 2nd time around
I've had the same issue with my WG, where you just have to run a lighter spring. Seemed to me like 2/3 of desired boost = spring pressure.
example, my target boost was 18, so I put the 11 or 12 pound spring in. I do run a MBC though.
Also, I think jegs/summit makes relatively universal starter heat blankets.
Re: 2nd time around
Inspired engineering is the name of his LED light company. Located in Florida. He does custom lights for jeeps and other jeep mods. Number is 1-305 814 5331
Re: 2nd time around
I assume you are using an AEM wiring harness?
If so could i get a pic of how you wired it to the 4 pin plug on the distributor?
Thank you.
Thank you.
Re: 2nd time around
3 pin for honda k coils. They are oem denso. 12v, ground and trigger.
Re: 2nd time around
I was asking about the wiring from the aem ems4 to the stock distributor.
Re: 2nd time around
Factory harness plugs into the aem v2 behind the passenger kick panel and is a direct replacement for the factory ecu. It's plug and play for my year car.
Re: 2nd time around
No special harness needed. Just have to wire in any extra sensors you want to add to monitor whatever you want.
Re: 2nd time around
Hey Cham, glad to see you around. Keep up the good work.
Re: 2nd time around
