Cute240sxGuy's KA24DET Build - 91/E85
Cute240sxGuy
Post by Cute240sxGuy » Sun Oct 11, 2015 6:42 pm
Thanks for viewing my thread :mrgreen:
This will be my first time tackling the KA-T project so any and all advice is welcome. I've had stock KA's, SR20's, and RB25s so this should be a fun time. It will more than likely be a slow build/process, however I will upload the thread with pictures whenever I do get a chance to work on the motor. Picked up my s14 rolling shell (with complete motor) non running about a month and a half ago (10/15/2015).
Picked up up a long block today for $100 and brought it home. Owner stated it had a water pump failure which caused it to blow the HG; I didn't mind as I will be rebuilding the block. My goals for this is going to be 400whp on E85 as my daily driver. Hope to have a dual tune for 91 & E85 as 91 is the highest here in Socal, besides the E85, however it's not always the easiest to get. Luckily for me I have 2 E85 stations both within 5 miles from me so I shouldn't have a problem, it's when I travel in the car it may become an issue.
I will also be doing an Auto to Manual conversion.
Parts I plan on using for the build:
- Clevite main & rod bearings
- Wiseco 9.0:1 90mm pistons
- Eagle H-Beam connecting Rods
- Felpro engine gasket set
- OSK Timing chain kit
- OEM Nissan oil pump rebuild w/ rebuilt regulator
- OEM Nissan water pump
- 97' KA 5speed Tranny
- XTD RB flywheel
- ACT RB HD street clutch kit
- JGS Rubber motor mounts
- JGS Rubber tranny mount
- Aluminum radiator
- PeakBoost top mount manifold
- Holset HY35
I plan on going the stand alone route as far as engine management goes, however if I end up not being able to fit it in the budget I'll more than likely go Nistune/Nismotronic.
HAPPY BUILDING!
***NOTE*** Make sure you ALWAYS label your baggies so you know which nuts/bolts go to what.
Scrapping away the silicone gasket with a blade.
*** Forbidden. ***
Last edited by Cute240sxGuy on Mon Mar 21, 2016 11:49 pm, edited 14 times in total.
Cute240sxGuy
Re: Cute240sxGuy's KA24DET Build - 91/E85
Post by Cute240sxGuy » Mon Oct 12, 2015 6:51 am
Intake Manifold removed from the head.
Exhaust manifold removed :)
MadMax
Post by MadMax » Mon Oct 12, 2015 7:50 am
Good plan! This was where my head was at when I first started my turbo KA build. Are you pulling everything apart for inspection or just hoping for the best? For safety Id have the crank inspected/polished/balanced, and check the head/cylinder walls for any severe scoring. Last thing you want is excessive metal collecting in those spots and floating around your motor after you just got done building it.
I vote for a top mount! If you are going to buy one though I recommend the DOC race top mount manifold for the quality of the steel, design characteristics, and fitment. If you want to have one custom fabbed, best to wait until you have the motor in your car for fitment. How much boost do you think you want to run?
Post by supakat » Mon Oct 12, 2015 8:57 am
Good luck with build. Instead of psi, how much power you want?
Cute240sxGuy
Post by Cute240sxGuy » Mon Oct 12, 2015 11:31 am
MadMax wrote:Good plan! This was where my head was at when I first started my turbo KA build. Are you pulling everything apart for inspection or just hoping for the best? For safety Id have the crank inspected/polished/balanced, and check the head/cylinder walls for any severe scoring. Last thing you want is excessive metal collecting in those spots and floating around your motor after you just got done building it.
Thanks! I will be taking the block and head to the machine shop to be hot tanked, inspected, and possibly have the cylinders honed (if possible without removing too much as I'm planning on std bore 89mm). I will have the head and block resurfaced/decked. I haven't thought about having the crank inspected/done as I am on a budget; would hate to put it all together to find out later the crank is warped.
I think I decide to go top mount! I also do plan on using the doc race manifold as it looks to be the best. The metal looks strong and the welds are fantastic; overall great craftsmanship.
Cute240sxGuy
Post by Cute240sxGuy » Mon Oct 12, 2015 11:32 am
supakat wrote:Good luck with build. Instead of psi, how much power you want?
I think you mixed them up ha! I never mentioned psi, only whp. Did you want to know the psi I'm shooting for? If so, probably around 25psi on E85 :).
Post by adamky » Mon Oct 12, 2015 12:59 pm
Cute240sxGuy wrote:I think you mixed them up ha! I never mentioned psi, only whp. Did you want to know the psi I'm shooting for? If so, probably around 25psi on E85 :).
I could be wrong, but I believe that supakat may have been responding to MadMax about the psi/hp comment:
MadMax wrote:How much boost do you think you want to run?
MadMax
Post by MadMax » Mon Oct 12, 2015 1:12 pm
Truu :) Also, In the OPs original post he says ~400 wheel is the goal on e85 probably.
I was more so asking PSI for manifold suggestions, I know people who get away with low boost on some cheaper manifold options. Granted the fitment, welds, and metal will have a higher % of not being up to par for when you do want to turn up the boost.
I'd sell you my rolling s14 shell, but alas you are a ways away! :)
Cute240sxGuy
Post by Cute240sxGuy » Mon Oct 12, 2015 4:20 pm
MadMax wrote:Truu :) Also, In the OPs original post he says ~400 wheel is the goal on e85 probably.
I plan on the doc race manifold as it looks comparable to the sheepey one I was using on my genesis.
I plan on running around 25psi give or take.
Post by supakat » Mon Oct 12, 2015 4:28 pm
Yea my bad. I did not see his 400whp comment. 25psi to make 400whp is using a smaller turbo which will heat up. Get something good for 550 and you will probably only need to run around 18psi to make that power. At 20psi with my HE351, I am around 420whp if I can remember correctly. This will also give you wiggle room to grow.
This is all theory. To get a good turbo, use a calculator to find how much air you need and find a turbo map that fits this value.
Cute240sxGuy
Post by Cute240sxGuy » Mon Oct 12, 2015 7:56 pm
supakat wrote:Yea my bad. I did not see his 400whp comment. 25psi to make 400whp is using a smaller turbo which will heat up. Get something good for 550 and you will probably only need to run around 18psi to make that power. At 20psi with my HE351, I am around 420whp if I can remember correctly. This will also give you wiggle room to grow.
This is the stuff I need in my life ! Keep the knowledge coming.
Any turbo recommendations? I was thinking of going with the Precision 5858 w/ ported S compressor housing.
Cute240sxGuy
Post by Cute240sxGuy » Tue Oct 13, 2015 8:30 pm
Not much of an update, however I did remove a few of the accessories that were on the block. I was planning on removing the head today but didn't get a chance to pickup the socket sizes that I needed. More than likely tomorrow or this weekend when I've got more free time. Had to replace thermostat and thermostat housing on wifes POS Ford Focus.
SORRY FOR THE CRAPPY PICS. IT WAS DARK IN MY GARAGE AND ALL I HAD WAS MY HEADLIGHTS LOL!
Post by adamky » Tue Oct 13, 2015 11:30 pm
You're off to a good start. My engine build parts list is almost identical.
Cute240sxGuy
Post by Cute240sxGuy » Wed Oct 14, 2015 11:12 am
adamky wrote:You're off to a good start. My engine build parts list is almost identical.
Right on, I'll have to check yours out also. Is there a power goal you have in mind for your build? What head studs will you be using?
Post by adamky » Wed Oct 14, 2015 4:16 pm
Shooting for 350 for right now due to money issues. I'm going to be using the CA625+ EVO9 headstuds from ARP. The goal being that once I get some extra cash, I'll upgrade the fuel system and shoot for 500-600.
Cute240sxGuy
Post by Cute240sxGuy » Wed Oct 14, 2015 9:39 pm
adamky wrote:Shooting for 350 for right now due to money issues. I'm going to be using the CA625+ EVO9 headstuds from ARP. The goal being that once I get some extra cash, I'll upgrade the fuel system and shoot for 500-600.
Are those the 11mm l19? I'm still trying to wrap my head around which route to go.
UPDATE!!!!
Picked up my Clevite main and rod bearings; standard size. Brand new never used for $70!!
Post by adamky » Wed Oct 14, 2015 10:11 pm
They are 11 mm, but the material is called CA625+ and it is stronger than L19 and the material is more stable. L19 has some weird properties where even a little oil from your skin can cause lots of corrosion.
Cute240sxGuy
Post by Cute240sxGuy » Wed Oct 14, 2015 10:16 pm
adamky wrote:They are 11 mm, but the material is called CA625+ and it is stronger than L19 and the material is more stable. L19 has some weird properties where even a little oil from your skin can cause lots of corrosion.
Right on man thanks for the info, I'm going to look into these. Any drilling/taping involved?
Post by adamky » Thu Oct 15, 2015 8:28 am
Yes, time serts are necessary in the block. You can use 11mm without any mods to the head though. 12mm requires drilling out the holes in the head as well as drilling/tapping the block. There's an oil galley that has to be modified as well.
Cute240sxGuy
Post by Cute240sxGuy » Thu Oct 15, 2015 10:11 am
adamky wrote:Yes, time serts are necessary in the block. You can use 11mm without any mods to the head though. 12mm requires drilling out the holes in the head as well as drilling/tapping the block. There's an oil galley that has to be modified as well.
Perfect thank you for the answer. Sorry for the noob questions lol.
Didn't really factor in having to rethread the block for upgraded head studs, should do more homework. Was planning on just running the 10mm ARP KA24de studs with cometic MHG shooting for around 25-30psi. I want to do it right the first time, so timeserts and 11mm will be up there on my check list.
superDorifto
Post by superDorifto » Thu Oct 15, 2015 1:39 pm
If your machinist is good you can get away without having to timecert the block for 11mm. I was able to.
Granted I might have pull out issues with ultra high boost, but well see when we get there.
Post by adamky » Thu Oct 15, 2015 2:16 pm
Really? The fact that the thread pitch is different would worry me, but that's good to know that it can be done.
Anyways, the machine shop that I use takes forever to get work done, and I already have my head there. When I had my bottom end machined and assembled 3 years ago, it took them 3 months to get it back to me. I don't want to wait on the block too, so I'm going to use this DIY kit that BoBaCK1 used for his build" viewtopic.php?f=3&t=60928&p=517811=#p517811
Cute240sxGuy
Post by Cute240sxGuy » Sat Oct 17, 2015 1:31 am
So today I looked at and purchased my s14 rolling shell ! It has motor and transmission however the block is toast. Probably going to try and pull the head tomorrow off of it and really inspect it. May use the head from this s14 KA if it's better than the one I currently have. Will keep you guys updated.
Post by cleantune » Sat Oct 17, 2015 4:29 pm
Doing it right! Your parts list is very similar to my own too. Its such a great idea to check everything out ahead of time while the engine is out- so much easier to work on. Looking forward to see what you come up with for this build :mrgreen:
As for standalone ECUs, I know its prob not a priority at the moment, but have you checked out some of the newer standalone ECUs that have "flex-fuel" support?
Cute240sxGuy
Post by Cute240sxGuy » Sat Oct 17, 2015 10:52 pm
cleantune wrote:Doing it right! Your parts list is very similar to my own too. Its such a great idea to check everything out ahead of time while the engine is out- so much easier to work on. Looking forward to see what you come up with for this build :mrgreen:
I have and not sure which one I want to go with. Currently I run a haltech on my genesis coupe with continental flex fuel sensor; running a dual 91/E85 tune.
Cute240sxGuy
Post by Cute240sxGuy » Sun Oct 18, 2015 4:07 pm
Started yanking these off the engine bay/motor today. Not too much time as I had other things to get done around the apartment before tackling what I did. So, pretty neat to see the KA with a huge hold in the block ;).
Cute240sxGuy
Post by Cute240sxGuy » Mon Oct 19, 2015 9:01 pm
Will also be doing a 5 speed swap to my car as it's an automatic! Picked up a 97' KA 5speed Transmission. I don't have $1k to fork out just for a z32 tranny mount KIT, plus the z32 tranny, PLUS clutch/flywheel kit. So, with my power goals, I'm hoping it'll last me a while before It blows lol (if it does).
Cute240sxGuy
Post by Cute240sxGuy » Thu Oct 22, 2015 9:17 pm
Not much time to work on the car nor the engine lately but I'll have plenty this weekend. On the other hand, some parts came in today!
ARP head studs came in today :]
Cute240sxGuy
Post by Cute240sxGuy » Sat Oct 24, 2015 6:50 pm
UPDATE: Was able to get a decent amount of work done today; Also my ARP main studs came in the mail. Don't you just love getting new parts in the mail !? :mrgreen:
Cute240sxGuy
Post by Cute240sxGuy » Sat Oct 24, 2015 6:56 pm
