My 4th KA-T build. Spare high compression build 12.6:1
nelson240sx
Post by nelson240sx »
Short story behind this build
I had a built turbo Miata I was having fun with but, wanted to get back to my roots.... I wanted another s-chassis. So I sold the Miata and picked up this coupe less than 24 hours after I sold the Miata. It had been sitting around for a couple years with a s14 sr that didn't run, picked her up and started working on her. Not too bad of a shell from a distance, but underneath she's not as pretty sadly. Fixed the sr (wiring issue) drove her at one drift event and she just wasn't what I wanted. Sold the SR and bought my buddies KA-T swap since he's wanting to go lsx. It's a s14 ka with around 140K miles on her, I sold his turbo setup (precision t3/t4, eBay manifold and precision 38 gate). I wanted to build something that's a little more responsive since I've been in the situation of trying to slide 3rd and just be outside the boost threshold.... No power there, lol.
My setup:
Stock s14 engine
AEM FIC6
Sti 510cc injectors
ISR 255 fuel pump
My first attempt at a tubular manifold
EFR6758 .83 exh housing (possibly a 7163 down the road))
Tial 44 vband gate
Basic cx racing FMIC
Remote oil filter mount
Oil cooler
P/S cooler
AN fitting on everything ( lol )
We'll see how far the 510cc injectors get me on e85, I'd be nice to hit the 300whp mark.
How I got the car
When I get the car cleaned up and running
3
3
4
4
Some pics of the ka build
5
5
6
6
cham
Re: My 4th KA-T build.... Project "Turbo Response"
Post by cham »
Looking good. Where did you get the manifold pipe kit?
nelson240sx
No kit, bought the flange off eBay and ordered a bunch of the weld els
Ace stainless / vibrant / eBay........ Depending on where you're at you might find them at industrial piping suppliers
nelson240sx
Getting closer a day at a time, hopefully I'll drive her by the end of September. Couple more weekends of working on her and I'll start on the wiring.... yay :angry-cussingblack:
nelson240sx
Almost there, another week or two and she should be driving
nelson240sx
Finished my catch can and fired her for the first time last weekend. Found a couple leaks I need to address and still need to build front and rear bumpers. Slowly and surely, one step at a time..... Lots of loose ends to take care of
Rick
KA-T.org Co-Owner
KA-T.org Co-Owner
Post by Rick »
Looking nice man!
nelson240sx
Just a quick update. I made it to the last local drift event of the year and other than a small oil leak I'm fighting with the AN fittings on the oil cooler she ran great. Quick spool (6psi @ 2,500rpm) and enough power to slide 3rd gear. I still want to mod the injectors and up the boost from the 9ish psi I'm currently running to 14-15psi. The 510cc sti injectors are maxed on e85 currently. Need to do a few angle mods over the winter, first thing is getting wheels that don't hit the frame.... I can't even get to the factory steering stops, lol
Post by adamky »
I like the custom catch can. Nice work.
nelson240sx
Building a second engine for fun and to have a spare for next year in case something happens I won't be down for long. This puppy is going hig compression. I don't know why but according to the internets ka24e pistons in a dual cam will next 11.2:1, this is incorrect. After punching numbers into a compression calculator I discovered that ka24e pistons will next roughy 12.4:1 compression. I also took .018" off the cylinder head which will bump it to 12.6:1. Not sure if that's too high for boost or not, but we will find out. Haha.
Engine build:
S13 ka24de - 12.6:1 compression
Head milled .018"
Ka24e pistons (-2.3cc dish)
248 intake cam / 232 exhaust cam
ACL bearings
NPR piston rings
REM polished valves, cams, rods oil pimp gears and crankshaft
Rem polished rod
Rem polished rod
Rem polished crank
Rem polished crank
Goku pistons lol
Goku pistons lol
Everyone loves clean head
Almost done
Almost done
Re: My 4th KA-T build. Spare high compression build 12.6:1
Post by supakat »
Nice to see you keeping the advance on KA's. Curios to see the numbers you make with this setup.
tuzzio
Post by tuzzio »
Did you use paint or PC on those covers? (like your upper timing cover)
Mine are off the car and I can sandblast and paint at work, just trying to get a nice factory looking silver.
nelson240sx
Thanks, Supakat
It's all "cast aluminum" engine paint.
Couple recent pictures.... EFR 9180 if I want to run all the boost, lol
nelson240sx
Starting the swap process, cant wait to see how responsive this girl is.
https://youtu.be/-N4_Yurq92s
nelson240sx
nelson240sx
nelson240sx
All future video updates are posted in the video section. Don't want to spam the picture threads with videos.
nelson240sx
Sold the car this past summer. Figured I’d post some pics of it to close out the build.
I don’t know why the interior shot is upside down….
OnTheChip
Post by OnTheChip »
"I don’t know why the interior shot is upside down…." I don't either because if you 'right-click' 'open in new tab' it's right side up???
