Divided T4/Twin WG Turbo Manifold+More!(updated 3/26/17)
Share ideas/designs/theories/tips/development:
(manifolds, chassis, personal projects, MIG, TIG, etc)
Re: Divided T4/Twin WG Turbo Manifold+More!
Postby Alonso » Mon Apr 28, 2014 9:10 pm
For the oil pan return I just used a tube. It used to be part of the oil return from a stock rb25 turbo. Idk what degree the bend was, I just made sure it lined up with the outlet on the turbo.
There are no vacuum/boost lines hooked up to the wastegates. Those are stainless steel hard lines used for coolant. Decided to hook up the water cooling ports on the wg's as everything is so close to each other. I bent the tubes and flared them myself.
It starts at the block as a single -6an(3/8") tube then splits to a pair of -4an(1/4") tubes then back to a single -6 line. The coolant returns where the temp sender for the gauge cluster used to be. The sender was relocated below the stock location.
Here's to give you a better idea-
Postby shift_down » Mon Apr 28, 2014 9:54 pm
Looks beautiful. Great job. I wish I had skills like this.
My build thread: http://www.ka-t.org/forums/viewtopic.php?t=57539
Postby Marcus » Sat May 03, 2014 9:08 pm
So awesome man! I hope mine see's the road this summer and I can make it down for a cruise.
Marcus
Wearer of Missing G-Strings!
Postby TanManS14 » Tue May 13, 2014 6:41 am
Looking sickkk, one of my favorite ka-t setups for sure. Cant wait to see her running!
Postby Alonso » Sat Jun 13, 2015 6:51 am
At long last...
https://youtu.be/_oOVIHF-Pg0
The CBR coils were ditched in favor of QR25DE coils. Even though they don't require an external ignition module, they did require a bit of fabrication to fit the valve cover properly. Well worth the effort as I can run standard spark plugs with these coils.
I'm been pretty busy so progress has been slow and will continue to be for a while. Slowly overtime I'll clean her up and get her ready for the street and the track. I'm just happy that I can start the car and drive it in and out of the garage lol
Re: Divided T4/Twin WG Turbo Manifold+More!(IT'S ALIVE! 6/13
Postby torquefreaks » Thu Sep 03, 2015 1:10 pm
How did you get the qr25de coils to reach the plugs?
torquefreaks
Postby adamky » Thu Sep 03, 2015 10:53 pm
What oil filter are you using on your turbo oil feed? Trying to figure out which one to get for my PT5857 dual ball bearing turbo...
Postby Alonso » Sun Mar 26, 2017 6:23 am
I haven't posted in a long time. I forgot I had uploaded a ton of pics but never got around to posting them, so I'll be dumping them here.
Postby Alonso » Sun Mar 26, 2017 6:49 am
Postby Alonso » Sun Mar 26, 2017 6:52 am
Postby Alonso » Sun Mar 26, 2017 6:55 am
Postby Alonso » Sun Mar 26, 2017 7:07 am
Update on the car:
Currently the car is sitting with cracked ring lands. 20psi on pump gas was a ***** blast but the stock Pistons couldn't handle it. This happened a year ago and the car has been parked ever since. Hopefully this summer I'll replace the broken piston so I can have a bit more fun with the car, this time run less boost and switch to e85.
These pics were taken at a local IFO event. I actually ruined the engine on the way to the event...
Feel free to follow/check out my work on Instagram- @alonso240
Re: Divided T4/Twin WG Turbo Manifold+More!(updated 3/26/17)
Postby nismo_dreaming » Mon Mar 27, 2017 10:04 am
Still one of my favorite S13 KA-T builds. Good luck with your rebuild, and should you ever want to sell that intake manifold or make another hit me up :D
1996 240sx SE LS1
nismo_dreaming
Postby s14fiend » Mon Mar 27, 2017 11:55 am
Nice welds props on the hardwork and attention to detail.
s14fiend
Postby JustAlex » Tue May 23, 2017 1:46 pm
Wow just skimmed through this thread and I've already seen some really sweet things. Digging the FN01R-C's by the way :)
JustAlex
Postby adamky » Wed May 24, 2017 11:18 am
Nice work as usual.
Postby Alonso » Sun Jul 09, 2017 8:59 pm
Well, ****.
Photobucket completely ***** up this thread along with many others. What free photo hosting sites are others using?
Postby Alonso » Fri Mar 22, 2019 2:49 pm
Wow. This thread has nearly 50k views! Glad to see photobucket pulled their head out of their ass...
I still own the car, and the car is still sitting with broken ringlands.
I’ve gotten so side tracked from this project, it’s not even funny. Let’s see, I learned how to do 3d CAD design, built a 3d scanner for scanning trinkets and for reverse engineering, I’m still working on my engineering degree while working full time(not recommended!), I got into 3d printing last year, and just finished building a new core-xy 3d printer. Let’s say that I’m ready to come home to.where it all began...
Stay tuned.
Postby s14fiend » Sun Mar 24, 2019 9:00 am
Alonso wrote:Wow. This thread has nearly 50k views! Glad to see photobucket pulled their head out of their ass...
Stay tuned.
Great to hear your making good moves in life to advance yourself.
Question about your exhaust manifold..... do you butt the sch10 pipes to each other and back purge or what size gap do you leave? Are you making more than one pass on your welds?
s14fiend
Postby Alonso » Tue Apr 09, 2019 12:15 pm
I don’t really leave a big gap between the pipes. Only before tacking, but just enough that after the tacking process the pieces are butting together from the shrinkage, yet they are not overlapping.
I bevel them to nearly a knife edge, but not make the bevel so wide that you have to run multiple passes to build up the material that was removed. It’s very possible to weld the joints in a single pass yet still achieve 100% penetration while keeping the face(both sides of the weld)flat with the parent material or slightly convex. There is no need for excessive build up as that’s just a waste of material. And yes, all butt welds are purged 100%, even during the tacking process.
“Balanced, as all things should be” :)
Postby s14fiend » Tue Apr 09, 2019 2:52 pm
Cool..... good to know.
s14fiend
Previous
Return to Welding/Fabrication
Users browsing this forum: No registered users and 18 guests
