mid-mount intercooler setup?
rusted_s14
Post by rusted_s14 »
So, I plan on re-doing my intercooler setup soon, and I really dig the way midmount setups are. Does the shorter piping really improve throttle response and turbine spool? Is it a bigger difference than a regular FMIC setup? If you guys can tell me which core would be best for the mid-mount setup and which would "flow" best and at the same time allow enough air towards the radiator? Any overheating problems with this setup with clutch fan? What bend piping is needed for this setup? Any help and input would be much appreciated!
Liger
Post by Liger »
By mid-mount are you referring to a V mount setup or a Front mount setup?
rusted_s14
Basically it's a front mount, but placed directly in front of the radiator and AC cores. Inside the radiator support for better ground clearance and I guess a more "clean" look. Main reason I want to do this is for better ground clearance and just maybe have even better throttle and turbo response.
SleepyS-14
Post by SleepyS-14 »
Thats where I have mine. Drifting loves to eat intercoolers otherwise. It sits right in front of the radiator. I just had to weld on some bends. Hope this helps.
Beer, the cause of, and solution to all of lifes problems.
SOHC S-14...
Post by p00t »
Thats how I have mine setup for now, I ditched the stock fan. If you push the rad back at all make sure to figure out some ducting so your not pulling engine bay heat into the front of the rad. It looks like even sleepy has a small gap to deal with.
Sleepy, love the color scheme man 8)
ICEMAN.KCMO
Post by ICEMAN.KCMO »
I am running mid-mount on my S14.... Couldn't love it more!!! i keep my factor bumper... nobody sees the I/C, and when the fans kick on, the draw air through the I/C when Im not moving! It is great!
Steve.
omgtofu
Post by omgtofu »
i plan on doing this as well..
slappynuts
Post by slappynuts »
Here is what I am making for some local guys.
Here is the upside down pic :green:
and an upside right pic.
oooooh the welds :green:
Nothing slows a car down more than unemployment.
Razo240sx
Post by Razo240sx »
^^^^^^^^ Any picture of that on the car? Looks Great!
ak_slick
Post by ak_slick »
See my Sig... I will add more pictures if you like just pm me. It actually was bolted below the front radiator support... I cut it out cause I got tired of having to clear it between pulling ka's and rb's in and out all the time. Before I cut it, I just removed the hood latch support and headlight motors and it fit perfectly.
whitesleeper
Post by whitesleeper »
How much is that intercooler selling for?
92 hatch, silvia front, cp pistons, eagle rods, alot of oem replaced parts, 750cc injectors, aem fpr, BW turbo, 4.40 vlsd, 18 psi, Nistune and SAFC, Energy suspension bushings and subframe spacers, megan coils.
jorge1190
Post by jorge1190 »
Anyone have pictures of this set up but with the AC condenser
godrifttoday
Post by godrifttoday »
wow realy nice
godrifttoday
cured13
Post by cured13 »
jorge1190 wrote:Anyone have pictures of this set up but with the AC condenser
+1
Unbound Yuurei
Post by Unbound Yuurei »
+1
+1
redpotatoes
Post by redpotatoes »
Unbound Yuurei wrote:
+1
+1
+1 but I doubt it's possible, not enough room. It would have to be a thin IC and a lot of cutting to make the pipes reach there destinations.
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
torch'd
Post by torch'd »
i also run a mid mount.... but i tilted my rad back a little and am running a honda 2 core half rad (joys of owning a ca18). never had a heating problem including last week drifting on a 95 degree humid day. and yes my setup (smaller ic and lots shorter piping) netted me almost 200 rpms quicker spool
going fast, i can do that... this going sideways thing is tricky.....
ak_slick
Post by ak_slick »
slappynuts wrote:Here is what I am making for some local guys.
The fabrication work looks top notch... I am curious what the pressure loss is across it with the 90 degree tube into the box end tanks. It would be an interesting thing to measure at the boost/mass flow they would be running.
