Welding Cast Iron/Cast Steel; questions/results
- Alonso
I was gonna say...I wouldn't use 308 rod on steel as it would crack. 309 would work but it shrinks way more steel. I think ER80s-d2 steel rod would be the way to go if you do decide to do this mod.
AWS D17.1 certified
AWS D17.1 certified
Since it was brought back from the dead anyways... When welding cast steel (did a couple factory SR manifolds and a custom KA turbo manifold) I've always used ER70S-2 filler rod because it is triple de-oxidized and will give you an x-ray quality weld.
For the stresses the knuckle will be under you must preheat it. I'd say preheat to 350*, weld it on DC Electrode Negative and amperage should be 1amp per 0.001" of material your welding. Electrode should be 2% Thoriated Tungsten, most likely 3/32" would be easiest but that's up to your preference. Your definitely going to want to make a couple passes. Two should do the trick I do believe if I remember the thickness of those knuckles correctly. Then after your done welding put it back in the oven, bring it back up to 350* then let it either cool slowly in the oven or if you have a bucket of sand available I'd stick it in that and let it cool.
Let me know how it goes and post pictures =)
Stephen
Stephen
- Alonso
Maybe because that's what I'm use to using and it was the first thing that came to mind. All the steel I do is 4130 and gets heat treated later anyways, a bit different from this knuckle I guess
Er70s-2 should be fine.
AWS D17.1 certified
AWS D17.1 certified
zombie bump.
anyone know WHAT type of steel casting this is? thinking about electron beam welding these bitches.
Just an update for those welding cast iron. Ive been using a rod my friend steals from work for me called Super 808 and it welds like a boss. I random google search brings up Palco 808 rod but Im not 100% sure thats the one since my friend brings it home in a lunch pale. The box says Super 808 on it but I cant seem to find it.
2JZGE NA-T -SOLD
10.3@131 27psi
