We weren't expecting this to be a novel idea.=) The crappy stripes that run down the valve cover on the other hand date the motor. So must be removed.Rick wrote:Wow...someone had an idea to polish a valve cover? wtf?
Rick
KA24E Custom Intake Manifold Is Finished=)
- jdmsilvia909
No, still waiting on my new turbo...and stupid ball joints (been 2 months). They've shipped me the wrong ones a few times.
That's kinda where I'm stuck. Then it'll take me a day or two to knock out all the welding. (intercooler piping, oil pan bung, downpipe, etc..)
JGS Precision
Square = turbulancesSolus wrote:*poke* Fram oil filter......
btw, very original intake manifold. (it's prettier polished) Personally I'd like a square one on my SOHC, I think it'd probably deliver more air too, but to each his own.
The air in the corners will swirl causing issues...
Splitting hairs here but also you'd find fitment issues with the throttle cable.
- Jordan Gladman
A linear tube design will do the same thing though, whale penis shaped manifolds are better in that they taper off. The last runner doesnt need as much airflow as the volume infront of the 1st runner so it doesnt make sense to have the shape the same all the way along...JGSturbo wrote:Square = turbulancesSolus wrote:*poke* Fram oil filter......
Point well taken, and that also makes a lot of sense Jordan. And yea...the more I think about it...the more I agree. But where oh where would we find a whale penis to fit our SOHC? Personally I see them for SR's all the time, but never for a KA.
After looking at pics of your SOHC I see a square shaped manifold there too.
Thats the first time I heard it called that Those are a good design as well, more to provide better response than max. power.Jordan Gladman wrote:A linear tube design will do the same thing though, whale penis shaped manifolds are better in that they taper off. The last runner doesnt need as much airflow as the volume infront of the 1st runner so it doesnt make sense to have the shape the same all the way along...JGSturbo wrote:Square = turbulancesSolus wrote:*poke* Fram oil filter......
I don't see how a round plentum has really any corners to allow air to swirl (turbulance)
Round tubes have the advantage of smoother flow in the mouth of the runners, where square or tappered square plenum will always have flat areas where the mouths of the ports are.
The only problem is the size of the tube (volume) which makes it not so good for putting around.
Its a good intake manifold verses the stock intake manifold, but the BEST design is a symmetrical one. The design above is a log style NON-symmetrical. Even the Whale shape is NON-symmetrical. I would have moved the throttle body opening to the center so that the air flows into the plennum between cylinder 2 and 3. This would have made the design symmetrical, which has a higher probability of equal flow to each cylinder...IE the bell shape curve. Symmetry of design is a desirable characteristic, either race or street, as it facilitates equal distribution of airflow to each cylinder.
-los
Not true on all accounts.
1) Its simple to build it. Just need to design it correctly from the beginning. If you "build as you go", your just asking for problems.
2) Again, it goes back to careful planning and design from the beginning. You only degrade other parts of the manifold if you planning is poor. The opposite is also true, if you plan it correctly, other parts will be improved!
3) Lots of science for small gains? Equal flow to all four cylinders is optimal. Its no different from something like compression ratio and other variables were you want to achieve equal specs across all four cylinders. Efficiency is the name of the game here. The more you can improve it of every aspect of the motor, the better and more powerful the motor as a whole will be.
Everyone will be different and will build, plan, and accomplish everything differently. The seriousness of a job and task at hand is what will determine everyones "thats good enough" finish line.
-los
- Jordan Gladman
The only specific part on the whole manifold is the head flange, i've seen universal, you weld plenums before that would suite the SOHC KA needs and save lots of trouble in building the plenum, just a thought, its awesome that you guys actually built one though.JGSturbo wrote:Unforchantly, its easier to talk about it than it is to build it...
And certainly you would end up degrading other parts of the manifold to get there
Basically alot of science for small gains......
I spent PLENTY of time designing this damn manifold, getting the throttle body to fit in the near stock location, locating the IAC valve, etc. etc.SOHC 240SX wrote:Not true on all accounts.
Everything else was pretty much determined by keeping as close to a bolt-on as possible. For runner sizes and plenum sizes etc. I used what I know works from the many other intake manifolds I have built. Its nice to want to make everything "perfect" (no such thing) but TRUST ME its a whole other thing to try to build it. If you don't believe me, well I tried
My design is NO different from the one on a 700WHP KA-E that was posted here a while ago (and about a 100 other intake manifolds on various 4 cylinder engines), it works and will accomplish the customer's given goals.
Tell me WTF is wrong with that?
^I agree that theory and actual excecution are two different beasts. I've also seens things that should've worked great on paper, in reality sucked. So it goes both ways. Either way I'm happy with it, and frankly I'm the one that is shelling out the cash for the product. Which is really the only person that matters. It will be just fine in execution of power ranges that I want, and I think Lance did an excellent job with the parameters given.
JGS Precision
Again, you have totally misunderstood what I said. I never said your manifold design was poorly designed, nor did I say its performance gains were poor or its construction. It is an upgrade over the stock manifold and has many merits and key features.JGSturbo wrote:SOHC 240SX wrote:quote]
What I did say was that your manifold is a NON-symmetrical design. A symmetrical design intake manifold is the superior layout compared to the other designs that were mentioned above, square plenums, round plenums, whale shape, etc.
Your manifold will work on a car making 70 horsepower or 700 horsepower. I didn't say it is not usable, do-able, or workable. I did say that due to the design, it does not promote equal air distrubtion to all 4 cylinders. Something like that is totally possible with careful planning....if you indeed plan to build something like that. Just look at what Nissan did with the RB25 intake manifold. For a stock manifold, it has a symmetrical design. Even the new 350Z have a symmetrical design. It may not be as clean looking, but it is more efficient.
I am not knocking yours skills, craftmenship, or intelligence. I am simply pointing out the facts about manifold design. I am almost done constructing my performance intake manifold. Surprisingly, it looks almost identical to your design, but the path of the incoming charged air is place in a different location to promote a symmetrical design and a bell shape curve probability of equal air flow to all four cylinders.
-los
I know what your getting at, the N/A 2JZ toyotas are a good example...
But a simple plenum manifold has better distrubtion that you might think.
Having the TB 90 to the runners makes the air turn 90 deg., the further you get down the plenum the smoother the air path to each runner is...
Thus equalizing flow. Now this doesn't work so well at lower throttle openings but thats outside the goal of this part.
I just don't see how your going to fit a TRUE equalized intake under the hood. If the RB25 intake was so great, why did they dump it when they made the RB26DETT?
Maybe you should send less time picking apart other people's work and more time building your own parts. That way you can show us how its suppose to be rather than just tell us how its suppose to be.
If I over stepped the line, I'm truely sorry but this is how I see it.
Don't take this as an insult, take it as a challenge
veilside180sx- sorry for turning your intake post into another post battle
Its kind of difficult to see that with all the "you should have done this or that" comments you always give every time something of my doing is posted. I'm sure you have your reasons, but downgrading somebodies hard work with saying I could have done this or that (when you know it would have been damn near impossible with the restrictions I was given on where everything needed to be and how much it needed to cost) and not expecting some kind of back-lash is well foolish.I am not knocking yours skills, craftmenship, or intelligence.
