I have EVO 9 red brembo calipers and am in the works of a bigger setup, but I will still offer these.
To use the MDX rotor?. Since the Z32 caliper bolts to the S-# rear knuckle/upright
it should be pretty spot on. The mains issue with that would be the E-brake. The Z32 uses a Drum that is cable actuated. I would just use a K spore E-brake system but some daily cars that sit would leak/or blow rear piston seals and roll down the driveway.
I am not sure the offset of the Z32 rear rotor VS the OE 240 rear brakes. If anyone has them and wants to post a pic of them side by side to see the hat highth.
I would just start over on the bracket and see how close it ends up being to the MDX rotor/OE caliper bracket.
Rear Big brake bracket.
- Mark Washington
