hey all, so i finally decided to make a more radical longer lengh manifold.
and im beginning to plan its design., and im wondering, what those who build their own collectors do the merge angle at
, and if anybody has tried do any offsets or any thing to improve sprialing to improve velocity.
im going with bottom mount, and the turbo is going to be placed pretty far forward, so collecter length isnt a big deal. , i just want to know the insight into good collector design.
collector merge angle??
- Jordan Gladman
The more acute the angle, the better IMO. Getting pipe to merge into a collector given a certain length with define the angle. Figure out how long your collector CAN be, then draw it up.
the angle doesnt affect the cut off length to where the turbo flange meets.
IM enough of a techno geek, i want to formula's to know what really works.
the length isnt to crucial, I was thinking around the 6 inch mark.
Iwont draw things either until i have the turbo sitting where i want., then i'll start planning lengths.
- Jordan Gladman
Im not sure what your first sentance means, but basically the tube end of the collector has to have full rounds to weld onto, the turbo side has to miter and meet to fit into your turbo flange. As the angle of the collector changes so will the minimum length you can cut the tubes to, thats all I was saying. I did my last collector at <30deg angle and it was around 4" long to get into a T3 flange.
