Jus14
Posts: 372 Joined: Mon Sep 21, 2009 2:25 am
Post
by Jus14 » Thu May 12, 2011 10:05 pm
Anyone have any tips on mig welding stainless ?
Jackasknissan
Posts: 1517 Joined: Thu Mar 29, 2007 5:27 pm
Post
by Jackasknissan » Thu May 12, 2011 11:16 pm
good luck on thin stainless, but proper gas, wire,
and if your doing open root stuff, either run a second bottle of pure argon to back purge, or use an apropriate flux
Turbo24sxt wrote: SOHC > DOHC ... period ...
oaznbeasto wrote:
Hey 6 posts, Go **** yourself! learn something then post[/quote
Posts: 3336 Joined: Thu Oct 12, 2006 5:55 am
Post
by TinyT » Fri May 13, 2011 12:34 am
what are you trying to weld? we can give you a better answer this way
Jus14
Post
by Jus14 » Fri May 13, 2011 7:57 am
had to cut my stainless exhaust to put a small twist on it because of clearance issues..so 3 inch stainless exhaust
Post
by TinyT » Fri May 13, 2011 8:33 am
Well I doubt you are gonna switch over to a spool of 308l or set up a purge system for one weld. so just weld it up and paint the weld with some high temp.
erich
Posts: 418 Joined: Fri Mar 11, 2005 1:42 pm
Post
by erich » Fri Nov 18, 2011 10:32 pm
Instead of back-purging you can use solarflux. It's worked well for me. It's expensive, so maybe you can bum a small amount from someone nearby. I think I've used 10% of a pint sized can doing three exhausts and two intakes out of stainless.
