almost step by step how to build a FAB9 rear housing
Share ideas/designs/theories/tips/development:
(manifolds, chassis, personal projects, MIG, TIG, etc)
RunninMeBrokeS13
Post by RunninMeBrokeS13 »
hey guys its been a pretty good wile since iv posted on this forum, iv been building one of my s13 to 25:1 spec, long story short the original motor was supposed to be a turbocharged lsx motor but i think i may throw a curve ball at the guys at the track and go back to my roots and build the nastiest KA-T out there. well back to the thread.
this isnt quite step by step but it gives you a good idea on what you have to do. if you want more information on it just pm me, iv made about a ton and a half of these things and know all the tricks for the most part.
so im skipping the first 2 steps because trying to explain these would take a century. but in a nutshell step 1 water jet the pieces step 2 bend the pieces.
step 3 your going to want to clamp the faceplate on a machined surface, doing this will keep it straight when your tacking everything up.
step 4 tack up the center to the faceplate make sure your top on your faceplate and the fill are in the correct spot for obvious reasons.
step 5 fit up and tack in sides be sure to once again put the vent hole on top
step 6 fit up webs with tubes and tack into place
step 7 fit and tack inner gussets
step 8 weld up the inside nothing to the face plate!
step 9 channel and v grove the outside of the box and prep for welding
step 10 bolt up a cover to the box and weld up the outside start with the box itself then the faceplate this will help with starting and stopping points and make a much cleaner look
step 11 cut axle tubes to length and put line up bar in and tack them then weld them into place
step 12 fit and weld up the back brace leave that dam line up bar in!
step 13 install your brackets pm me for further instruction on this.
step 14 install the ends onto the axle tubes with line up bar. then fill drain and vent logo install and shes done!
viewtopic.php?t=45810
aim-runninmebrokes13
its not turbo lag, its foreplay
E-Mance? think again, do it right do it white.
240drew wrote:The 240sx rolled out with a motor that was stout as queen latifas ankles and as sophisticated as a cannon ball.
Post by supakat »
Impressive. Wish I could weld like that.
Post by adamky »
Damn, that's impressive work.
Post by TinyT »
Looks good! Lets see the chassis though! 7.49 and faster is serious business
Post by beercandrifter »
which fab 9 kit was that, was taking a look at the chassisworks page,
also, what are you doing for the driveshaft? custom for mating with the ford diff?
RunninMeBrokeS13
tiny ill post some pictures up shortly of the chassis. and it wasnt a kit i did that at work. all made in house at S&W Race Cars.
RunninMeBrokeS13
here are a few shots of the car from a little wile ago ill need to take some updated ones for you but this gets you an idea.
this one was just taken with a mock up rear
RunninMeBrokeS13 wrote:tiny ill post some pictures up shortly of the chassis. and it wasnt a kit i did that at work. all made in house at S&W Race Cars.
ahh sorry, you said fab 9, instantly assumed it was a kit that you modified. nice work
that rear tube chassis looks mean =)
Post by TinyT »
Pretty cool man! What front suspension are you gonna run? Isn't tig welding the tubing when you can stand in the car a lot nicer? haha.
RunninMeBrokeS13
TinyT wrote:Pretty cool man! What front suspension are you gonna run? Isn't tig welding the tubing when you can stand in the car a lot nicer? haha.
haha yea man no doubt although iv done my fair share laying down using my head for the pedal, you know what i mean. hopefully i can get my wheels and tires soon and get this thing put together!
RunninMeBrokeS13
though this one might be interesting for ya's, here is a top fuel rear all domex all tig welded. the ultimate weld strength test 8000hp getting driven to this beast, hopefully it holds lol.
Post by TinyT »
What front struts are you gonna run? And why are there tubes running into the stock tunnel? When is all of that coming out for the new floor and tunnel bars that run up to the mid plate?
