Distributor delete cap
Hey all help needed. I am going to be doing the maxima coil on plug. So far I do not know what to do with the distributor cap after I convert. I have seen pics on here of ppl running them open but I would prefer a CNC cap to protect the optics and the cas disk from debris. Does n e one know where I can get this done or where to buy it??
Eagle rods; Wiseco dished pistons; balanced rotating assembly; Supertech valves, springs, retainers, seals; 248/248 cam swap w/ JWT adj sprockets; ACT 6puc clutch; 11lb flywheel; GT3582r journal bearing turbo; 600cc JECS; Godspeed intake manifold; Cometic .075" head gasket; ARP studs upper and lower engine; Maxima coil on plug conversion, xcessive distributor delete cap; AEM series 2 = 404whp 316ft lbs torque
Man tanks so much. Nailed it on the head exactly what I needed.
