I know have seen some people with top mount KAT setups that ran into clearance issues with the Brake Master Cylinder, and the brake lines. I saw a picture from here a while ago where someone had fabbed up some brake hard lines that instead of connecting from the stock left side of the bmc, came around the brake booster and connected to the right (obviously they changed the BMC because it had the BMC had connections on the right side as well).
In preparation for my kat I was going to do a 300zx front brake swap on my 95 240sx w/ABS. To keep the brake bias the same I was going to use a BMC from and Nissan S15, which comes stock with 300zx brakes in the front and the same brakes as the S14 brakes in the rear. (You can use a BMC from a 2000 Xterra same specs as the BMC from the S15 MUCH less expensive to get in the US). The only Nissan BMC I can find with the proper specs to keep the brake bias the same, all have the connections on the right side. I need to get new hard lines so I can change my bmc and have everything reach over the brake booster and connect to the right.
I know I saw a picture of someone what has already done this, I wish I had saved it, does anyone know where I could get hard lines fabbed up for this? or at least have access to a picture where someone has done this or something similar so I can get a good look at it?
Fabbing some brake lines for Brake Master Cylinder
One can just re-bend the stock lines too, paying careful attention not to kink the lines.
Jegs sells hard lines, not sure what size the 240 ones are though:
http://www.jegs.com/p/JEGS-Performance- ... 4/10002/-1
they are 45* flares if you buy a tool from an autoparts store
can also get a basic tube bender from the autoparts store.
brake tubing is pretty easy to work with, easy to kink if bending by hand without a tool.
I've done this on my S13, and it wasn't a simple swap
I used RHD Z32 BMC + S13 non-ABS brake booster
- there is not enough room, the strut tower had to be hammered in about 1" deep
- bended stock brake lines wasn't easy and they barely reach with a bit of tension on the lines which I don't like. So I will be swapping the lines later.
on the plus side it does give you 1" extra clearance
