AMMFAB picture thread
ammfab
Post by ammfab »
ok so some people suggested i start a thread in here and i finally got the time to do it so here it..... ill put pics up of things from here on out mostly unless i get bored and feel like posting some pics of older stuff. ill start with the head i did for sil-coupe followed by some subie heads i just did....
ka24e street/strip porting.....
and some ej25 subie heads i just did.....
overall shots.....
inlets of intake ports.....
close ups of intake ports.....
combo chamber side view of intake port short side radius....
combo chamber side view of intake bowls from different angles.....
and a close op on the intake port throat area.....
straight exhaust port....
dog leg exhaust port......
combo chamber side view of straight exhaust port short side turn....
cloe up of exhaust port throat.....
different angles of straight exhaust bowls.....
different angles of dog leg exhaust bowls.....
long side view of exhaust bowl....
above view of combo chambers......
im not gay but my car is.....
Post by sdaigle240 »
wow that is beautiful sir. and i never realized how much better the SOHC head looks flow wise.
any tips or reccomended products? were just back yard mechanics, so def not trying to make a business out of it. but a lot of us have diy port jobs including my self. thinking back to your first couple times you probably have a good idea of the results were getting so any suggestions are welcome.
( I just used a barrel shaped thing with like 10 "paddles" cut into it for shaping then just various grit flappers (1/4" rod with a slit in it to slide some paper) smooth as i could on the exh and 80 grit on the intake .) [/url]
Post by airman »
I was gonna ask the same question. What equipment do you use?! Beautiful ports.
Oh, and nice photography. Would have been disappointing if they were all blurry and mal-composed :)
Keep it up. I always enjoy the eye candy of good workmanship.
500hpKA240sx
Post by 500hpKA240sx »
beautiful job man. very impressive. porting is a true art work.
ammfab
Post by ammfab »
thanks guys nothing special used just the standard issue carbides and catridge rolls. with pneumatic die grinders.
mike
p00t
Post by p00t »
Looks great, very consistent finish.
Have you tried polishing the exhaust more to keep carbon from building up?
ammfab wrote:thanks guys nothing special used just the standard issue carbides and catridge rolls. with pneumatic die grinders.
mike
mike,
Any tricks for working in the bowl? im just scared of the bit jumping and hitting the valve seat. maybe i just need better practive with my bit speed but every once and a while it jumps. i didnt know if maybe there were some special seat protector things or i just need more practice.
Post by supakat »
I used carbide for shape and flap wheels for finish.
ammfab
Post by ammfab »
p00t wrote:Looks great, very consistent finish.
negative sir, waste of time imo but thats just me. 60-80 grit for everything, carbon is going to stick not matter what.
mike
ammfab
Post by ammfab »
sdaigle240 wrote: mike,
no secrets, but practice makes perfect for sure. u just gotta move the head around and position it so ur not trying to carbide in an awkward position to help prevent it from grabbing an jumping. this is why when i port heads i also do the valve job and resurface just in case i ooops it. it use happen alot, barely any now a days.
mike
ammfab
Post by ammfab »
fitted and tacked this manifold up this past weekend..... its even for a nissan qr25de.....
mike
sil-coupe
Post by sil-coupe »
Nice work man!
Marcus
Wearer of Missing G-Strings!
Post by Marcus »
Your work is amazing. I just got convinced of who to contact for my next port work. Beautiful work...period.
Also I'd like to say your latest post awesome as well...but with an office chair in one shot, and a random supercharged 4 cyl in another deserves a "Like a BOSS!" emoticon.
ammfab
Post by ammfab »
Marcus wrote:Your work is amazing. I just got convinced of who to contact for my next port work. Beautiful work...period.
Lmao..... Thanks. I have 2 office chairs in the garage. They work great cause they are comfy and telescope up and down depending on what bench I'm at. Here's finished pics of the manifold. ......
Mike
Marcus
Post by Marcus »
Awesome man. Curious, what cup on your tig are you using to get to all those hard to reach places?
ammfab
Post by ammfab »
Marcus wrote:Awesome man. Curious, what cup on your tig are you using to get to all those hard to reach places?
either a jumbo #12 or a extra long #4 both on a #9 torch.
mike
trk240sx
Re: AMMFAB picture thread
Post by trk240sx »
I know this is an old thread, but I had to post a few comments. This is some of the best head and fab work I have seen. Great work!
Also was wondering if you happened to flow bench the heads prior and post work? Love to see some numbers..
sil-coupe
Post by sil-coupe »
I do not recall if the e-head was flow benched before hand. I'm pretty sure it was after, I remember hearing a lot higher numbers. If you want to get in contact with mike... The best way is instagram #ammfab I'm sure he hasn't been back here in a long time. He said he's got too many fab threads to keep up with.
