Suspension Mods and Fabrication
Post by sdaigle240 » Wed Sep 03, 2014 10:19 am
wish this fabrication section was more active. maybe this will get more people to post their efforts.
Here are some recent mods ive done to my suspension / steering setup. after 1 event, i couldnt be happier with the result.
Knuckles, Cut N Chut, 3 7/8" ball joint to tierod center to center, no ackerman correction
only have one blury photo of the root pass. 200 amp tig no filler, then ran 200 amp mig with mild steel wire. V groove prepped joint so i could get 100% penetration. came out purdy good.
Re: Suspension Mods and Fabrication
Post by sdaigle240 » Wed Sep 03, 2014 10:23 am
Steering Rack Relocation ~ 1"
this is a really quick and easy mod - if you have the subframe out already. ive since added PBM rack bushings as the Energy Suspension ones quickly tacked out after install (clunking etc) as a note, with JGS mounts, the rack relocation and PBM mounts, i had to space up my mounts almost an 1/8" for the rack to clear the pan.
apologies for photo quality
notching to clear the rack knuckle
more clearancing. yeah yeah i could of done this on the bridgeport at work but whatever
buncha access grinding for a 16 socket
Post by sdaigle240 » Wed Sep 03, 2014 10:24 am
Lower Control Arms - Extend, Box, Notch and add Stops
added 1/2", box'd, notched'd, adjustable stopper and added some meat to the knuckle to accommodate it.
Post by sdaigle240 » Wed Sep 03, 2014 10:37 am
My goals were:
more angle
quicker steering ratio
wider track - while maintaining wheel well clearance with the added angle
Bonus was
INSANE TURN IN GRIP - this was mostly from the increase in camber up front. i loose contact patch while driving straight but as i turn in i get progressive grip as i gain contact patch. i cant get over it, i would of run way more camber in my autox days had i known.
see, the bitches love it too
Post by sdaigle240 » Tue Sep 09, 2014 12:25 pm
y'all sukaz dont hack n melt metal n stuff?
Bubba
Post by Bubba » Tue Sep 09, 2014 6:31 pm
I don't posess the knowledge or tools to safely perform projects like this.
Looks good from where I'm sitting though.
My car is dead stock.... ish
http://mobileimports.freeforums.org
Post by sdaigle240 » Wed Sep 10, 2014 5:25 am
on page one of my build thread, i had never done more than an oil change. you got a harbor freight around you? dig in man and get some tools. 4 1/2" die grinder, 15$. could get a flux welder for 100$ pretty much anything you need, its cheap but always gets me through a bunch of jobs. and im relly just cutting and grinding **** untill its fits up. then i melt it together. thats it lol. and thanks dood.
Post by airman » Wed Sep 10, 2014 10:24 am
Hopefully once I get more done on my car's foundational stuff, I can start tinkering with neat custom stuff like this :D
Bubba
Post by Bubba » Wed Sep 10, 2014 6:36 pm
Already bought myself a decent little Lincoln MIG setup.
Looking for someone with a tubing notcher and a bead roller locally that I can use for a day to make a tube front and replace the garbage sheet metal in front of my strut towers. Managed to teach myself to weld a little when I first picked it all up. Having a knowledgeable person on hand would make this all a little easier to absorb, but I'm just winging it for now.
Post by sdaigle240 » Thu Sep 11, 2014 5:30 am
thanks airman. bubba, hit up youtube you can watch pros lay beads and give tips for days.
