Switching to E85... keep the water meth injection or not?
So, I've been running 93 oct + water/meth injection for a while now. I've decided to switch to E85, but I can't decide whether to keep the water meth injection, or just run without it.
I know E85 by itself will work fine because of it's high octane. But, I kinda like the cooling effect the water meth has on the intake charge. Also, since I spray the water meth pre-supercharger, it helps to seal the rotors and I usually get an extra 1-2 psi of boost.
Anyone have any thoughts on this? Overkill?
Better to be safe than sorry. Extra protection if you ask me. Also, since it generates 1-2lbs more, why not?
Plus even lower intake temps for even more timing/power.
I like to think of it like this, STi/EVO guys are intercooled and still add water meth for more power. That's basically what you would be doing where e85 would be your 'intercooler' in comparison.
I'm not completely up to date on E85 tuning and I remember seeing something like you need 30% more fuel running E85 then you do running gas.
Since you're running more fuel and on top of this plan on running meth/water is there any chance of hydro locking the motor?
At what point does that become a concern?
Jeff
- nismoautoxr
in my car when I switch tables it works out to more like 20-25% more for E85.
To the hydrolocking question...Im not sure . I guess its possible since you're going to be adding more fuel but Id be inclined to say it should not be a factor but then again Ive not run the combination .
Ricky Ragan,
Thanks for the advice. I did some searching online and this has definitely been done before. I think I will run both. I may run a little less methanol in my tank than I do with 93 octane though. I run 50/50 now. I'll probably try 30% meth and see how that does.
If the spray is atomized enough, then no, it couldn't hydrolock your motor unless it literally pours into the cylinders in liquid form. The water/meth will immediately flash to steam/a gas and lower combustion temperatures as soon as it hits the cylinder.
I say why not. As you and other people have mentioned lower intake temps is always a good thing and you can't ever be too safe so i would try it both ways to see if the advantages warrant running both. Do you monitor you intake temp?
Daily: 2003 Super Black 350z
Project: 1991 Cherry Red Pearl Rocketship Coupe ka-t (simple n62 maf, Master power 50 Trim, 550cc STI injectors, tial 38mm, enthalpy rom tune, rest of the goodies set up)
That's what I was planning. I want to use the water meth as an extra measure of protection and to get the extra 1-2 psi of boost.klattr1 wrote:Here's my advice...tune for the E85 but don't tune for the water/meth injection (meaning don't add timing or lean it out when using it)...that will keep the setup safe and reliable.
Thanks for the advice everyone. I really hope to get this thing running on E85 and get it dyno'd within a month or so.
- emo_tactical9
When you are using a hose as a fuel injector.body80 wrote:I'm not completely up to date on E85 tuning and I remember seeing something like you need 30% more fuel running E85 then you do running gas.
I do have a PLX air intake temp gauge. I don't have a way to log it, but I can glance at the gauge during a wot pull.sik_z33 wrote: Do you monitor you intake temp?
Post meth. It's mounted to the top of the supercharger plate.
Wouldn't it be pre-meth now that you have your nozzles mounted on the runners?adamky wrote:Post meth. It's mounted to the top of the supercharger plate.
What kind of temps are you seeing?
I am no longer running the individual port setup since I am switching to E85. I just have one 175 ml/min nozzle at the supercharger inlet. The air temp sensor is mounted in the supercharger plate, kind of between runners 1&2.
I haven't driven the car a lot because I have still been working on little issues here and there, such as vacuum leaks. I've seen the temps get over 200 on a hot day. Most days, they run around 160 degrees. I have not had a chance to see if the temps drop with the water/meth setup running and full boost.
The supercharger outlet blows up directly at cylinders 1&2. I guess that's why I put it there...? Also for convenience. It's a pain to get the sensor in and out of the manifold due to the way the wire kinks as I'm threading it in. I have to remove the glovebox and pull all of the wire through the firewall when removing/replacing it. It would really be tough if I had it between cylinders 3&4.
Here's a recent pic to show where it is. It's that wire with the red part on it coming up between the runners:
