Switching to E85... keep the water meth injection or not?
For those other forced induction brothers
Post by adamky »
So, I've been running 93 oct + water/meth injection for a while now. I've decided to switch to E85, but I can't decide whether to keep the water meth injection, or just run without it.
I know E85 by itself will work fine because of it's high octane. But, I kinda like the cooling effect the water meth has on the intake charge. Also, since I spray the water meth pre-supercharger, it helps to seal the rotors and I usually get an extra 1-2 psi of boost.
Anyone have any thoughts on this? Overkill?
Post by supakat »
Better to be safe than sorry. Extra protection if you ask me. Also, since it generates 1-2lbs more, why not?
TryingToTurbo
Post by TryingToTurbo »
Plus even lower intake temps for even more timing/power.
I like to think of it like this, STi/EVO guys are intercooled and still add water meth for more power. That's basically what you would be doing where e85 would be your 'intercooler' in comparison.
body80
Post by body80 »
I'm not completely up to date on E85 tuning and I remember seeing something like you need 30% more fuel running E85 then you do running gas.
Since you're running more fuel and on top of this plan on running meth/water is there any chance of hydro locking the motor?
At what point does that become a concern?
Jeff
nismoautoxr
Post by nismoautoxr »
in my car when I switch tables it works out to more like 20-25% more for E85.
To the hydrolocking question...Im not sure . I guess its possible since you're going to be adding more fuel but Id be inclined to say it should not be a factor but then again Ive not run the combination .
Ricky Ragan,
Post by adamky »
Thanks for the advice. I did some searching online and this has definitely been done before. I think I will run both. I may run a little less methanol in my tank than I do with 93 octane though. I run 50/50 now. I'll probably try 30% meth and see how that does.
Post by airman »
If the spray is atomized enough, then no, it couldn't hydrolock your motor unless it literally pours into the cylinders in liquid form. The water/meth will immediately flash to steam/a gas and lower combustion temperatures as soon as it hits the cylinder.
sik_z33
Post by sik_z33 »
I say why not. As you and other people have mentioned lower intake temps is always a good thing and you can't ever be too safe so i would try it both ways to see if the advantages warrant running both. Do you monitor you intake temp?
Daily: 2003 Super Black 350z
Project: 1991 Cherry Red Pearl Rocketship Coupe ka-t (simple n62 maf, Master power 50 Trim, 550cc STI injectors, tial 38mm, enthalpy rom tune, rest of the goodies set up)
klattr1
Post by klattr1 »
Here's my advice...tune for the E85 but don't tune for the water/meth injection (meaning don't add timing or lean it out when using it)...that will keep the setup safe and reliable.
Post by adamky »
klattr1 wrote:Here's my advice...tune for the E85 but don't tune for the water/meth injection (meaning don't add timing or lean it out when using it)...that will keep the setup safe and reliable.
That's what I was planning. I want to use the water meth as an extra measure of protection and to get the extra 1-2 psi of boost.
Thanks for the advice everyone. I really hope to get this thing running on E85 and get it dyno'd within a month or so.
emo_tactical9
Post by emo_tactical9 »
body80 wrote:I'm not completely up to date on E85 tuning and I remember seeing something like you need 30% more fuel running E85 then you do running gas.
When you are using a hose as a fuel injector.
Post by adamky »
sik_z33 wrote: Do you monitor you intake temp?
I do have a PLX air intake temp gauge. I don't have a way to log it, but I can glance at the gauge during a wot pull.
klattr1
Post by klattr1 »
adamky wrote: I do have a PLX air intake temp gauge. I don't have a way to log it, but I can glance at the gauge during a wot pull.
Where do you have the sensor mounted? post or pre-meth?
Post by adamky »
Post meth. It's mounted to the top of the supercharger plate.
TryingToTurbo
adamky wrote:Post meth. It's mounted to the top of the supercharger plate.
Wouldn't it be pre-meth now that you have your nozzles mounted on the runners?
What kind of temps are you seeing?
Post by adamky »
I am no longer running the individual port setup since I am switching to E85. I just have one 175 ml/min nozzle at the supercharger inlet. The air temp sensor is mounted in the supercharger plate, kind of between runners 1&2.
I haven't driven the car a lot because I have still been working on little issues here and there, such as vacuum leaks. I've seen the temps get over 200 on a hot day. Most days, they run around 160 degrees. I have not had a chance to see if the temps drop with the water/meth setup running and full boost.
torch'd
Post by torch'd »
adam i know ur setup is well developed. wondering y u placed it there??? ive been monitoring things on my sohc and noticed 3&4 are significcantly hotter thats y i ask.
johnny
going fast, i can do that... this going sideways thing is tricky.....
Post by adamky »
The supercharger outlet blows up directly at cylinders 1&2. I guess that's why I put it there...? Also for convenience. It's a pain to get the sensor in and out of the manifold due to the way the wire kinks as I'm threading it in. I have to remove the glovebox and pull all of the wire through the firewall when removing/replacing it. It would really be tough if I had it between cylinders 3&4.
Here's a recent pic to show where it is. It's that wire with the red part on it coming up between the runners:
