hardbody DE swap (56k beware)
For those truckers!
Postby Otto's » Tue Aug 19, 2008 9:18 pm
Just curious could you have just gotten an oil pan and pickup from the frontier DE motor and bolted it on?
Otto's
Postby andrew_r_mcintosh » Tue Aug 19, 2008 10:40 pm
I believe soo....
Been reading this forum for a few hours now as I am planning a ka superchage swap in my 81' 720 4x4 and all the guys over on the msn 720 group....tloof included, recommend using the truck block if going with the DOHC as it saves a lot of work.
Regardless, you got it in and i'm impressed and inspired.
Props.
andrew_r_mcintosh
Postby schmauster920 » Wed Aug 20, 2008 8:41 am
To answer your question, i heard that the frontier DE pans were a completely different bolt pattern, and oil pump is further back.. I tried to get one to compare through my parts store neighbor, but no luck... The frontier motors are a direct drop in i hear, but i wanted the girdle!
Im working on figuring out some of the wiring and its a huge pain :evil:
Postby andrew_r_mcintosh » Wed Aug 20, 2008 3:09 pm
andrew_r_mcintosh
Postby schmauster920 » Tue Aug 26, 2008 1:59 pm
JGS manifold with a t2 flange on the bottom side as you can see. im going to have the origional good welding shop weld a t3 inlet and external wg flange from jgs on there. im thinking where im holding it is going to be the best spot, and wg on the bottom angled towards the motor to keep it away from the drain pipe
I like the clearance better then 240s thats for sure, im going to use silicone header paint and heatwrap the downpipe so it doesnt heat up the firewall and floor like it did with the header. Some sort of bent aluminum heat shield should be sufficient to block the turbo and downpipe heat from the brakes and reservoir.
Ill be adding a remote mount filter kit with an oil cooler, along with a temp sensor in the oil pan so i dont fry this thing too quickly (i hope)
Stupid imageshack wtf is going on with my pictures lol
Ill make the rest of the pics work sometime in the future, what a pain
Last edited by schmauster920 on Thu Nov 03, 2011 1:50 am, edited 2 times in total.
Postby slownissan » Thu Aug 28, 2008 12:18 am
looks good bro cant wait to see it all together
slownissan
Postby schmauster920 » Fri Sep 05, 2008 1:39 am
More wiring action updates from the frontlines!
ok on with the pictures (no longer hosted by imageshack haha):D
Ooo i love body wires!
yay wires!
The blue junk is some RTV i used to seal the shifter because i felt it was letting in air
Ive got some mystery wires running from the engine harness to the dash im guessing, i love these little suprises! maybe ill have to tear out my dashboard to track them down! I sure hope so! Ill see if i can figure it out by looking at my harness
Ill be using this turbo... just kidding but what was mazda thinking? Anyone seen one of these inbred turbos on a KA?
The stuff under the dash came out really easily and i got to take my old AC junk out from under the dash and clean the handfulls of leaves out as well
Postby slownissan » Fri Sep 05, 2008 2:16 am
looks like fun lol
slownissan
Postby Nitrobanshee » Fri Sep 05, 2008 7:09 pm
I cant stand the gray goop nissan puts on the wire harness.
That crap gets on everything.
1995 Nissan Pickup truck running Megasquirt V3.0 MSII 2.88 EDIS with a turbo.
Dyno #s 354WHP 381Foot pounds
KA24E-t Power
Nitrobanshee
Postby schmauster920 » Fri Sep 05, 2008 7:48 pm
yeah a lost a little faith in nissan the day i discovered the grey goop!
Charcoal lighter fluid removes it very well i might add!
Postby schmauster920 » Sun Sep 14, 2008 3:49 am
little progress... it looks far too clean in my dirty ass truck
Check out the raisin bran!
Postby schmauster920 » Wed Sep 17, 2008 6:53 pm
Got a tuned ecu for 550cc injectors, so i can upgrade from the 370s i have sitting around (270s on there now i know)
Got the s13 distributor in, almost ready for the N/A startup and neighbor pissing off :)
Anyone know what kind of flange that is? its a T3 inlet, downpipe is def not the reg t3 or t3/t4 ... im guessing it came stock on some car
Ive got the 240 alternator on the truck bracket so i can use a single V belt without power steering!
Postby schmauster920 » Sat Sep 20, 2008 10:43 pm
ok so slownissan has been helping me a crapload with the wiring and we got it to crank today, i think we have a bad coil but ill know more when we swap another one in tomorrow... still waiting on piping and manifold cutting, welding, and some flanges... lots of little stuff i dont know about yet haha
Also i realized due to the pan being switched around my dipstick no longer works, it just hits the pan since its in the wrong spot to go down into the sump.. Im thinking get a metal tube and have it welded to the pan
Postby schmauster920 » Tue Sep 23, 2008 10:00 pm
It lives... kind of... i need exhaust for my wideband, it idles well but thats it, i need to do some tuning
Still a ways to go till i have boost
Postby schmauster920 » Thu Sep 25, 2008 9:50 pm
ok i didnt want to drive my fellow appartment goers crazy so slownissan threw down some beads for me on my new top mount muffler :) ill be cutting a much bigger hole so i dont care... This is so i can get a baseline tune with the safc2
cut a hole in the hood and forget about the boost :) jk
Postby julienmark » Fri Sep 26, 2008 12:44 am
That is down right silly,
The truck will now pull to the left due to the wind resistance, the muffler should always exit the center of the hood.
julienmark
Postby andrew_r_mcintosh » Fri Sep 26, 2008 1:02 am
I hope thats a RHD hardbody too...
andrew_r_mcintosh
Postby schmauster920 » Fri Sep 26, 2008 11:48 am
Thank you, i forgot about the center of the hood exhaust rule, i was wondering why it kept pulling to the left at 150+ hahaha Ill put a cat on the end of it and be legal :P
Us 4 cylinder guys dont get the big blowers coming out the hood, i needed something to block my view so i can look cool too!
ill try to get a driving video around the block with sound lol
Postby schmauster920 » Sat Sep 27, 2008 5:06 pm
Slownissan and i got the timing right on after some distributor restabbing (it was one tooth off from the s13 dist, swap) and after that it fired up nicely and idled quietly, we took it around the block and got some funny looks! Just need the other stuff, ill be sad to see my smoke stack gone :(
Postby schmauster920 » Sun Sep 28, 2008 7:58 pm
http://videos.streetfire.net/video/Top- ... 2501773b4c
heres the video of it alive in the car port :P
Postby schmauster920 » Sat Oct 04, 2008 9:22 pm
I miss my top mount muffler :(
heheh its coming all along, still need exhaust and intake pipes, small oil fittings etc etc
slownissan has donated an intercooler for me to use for the time being
Postby schmauster920 » Sun Oct 05, 2008 7:40 pm
more restrictive then the top mount muffler :D
Junkyard exhaust FTW :D 2 3/4 all through, except for the crappy muffler for now, i might get one of those sweet 15 dollar 'turbo' mufflers from auto zone with 3 inch in and out
Im using alumized 2 1/2 mandrel bent exhaust piping (cleaned in and out) for intake pipes
Total for exhaust and intake charge pipes... 43.65 yay cheapness
sleeper supreme, i think ill take a lot of people by suprise :twisted:
Postby Kfred » Sun Oct 05, 2008 8:29 pm
All "turbo" mufflers are pretty restrictive. Resonator style mufflers are much less restrictive, dynomax carries straight thru packed mufflers.
Unfortunately they aren't $15, but a glass pack is and will work.
RIP Nate(480sx)...
Kfred
Postby schmauster920 » Sun Oct 05, 2008 9:07 pm
i didnt know that they suck... ill probably pick up something decent later down the road, i dont want it to be too loud (till wastegate opens) less backpressure is good of course!
Thanks for the heads up about the 15 dollar 'turbo' muffler, i guess you really cant cheap out on much :P
Postby Kfred » Mon Oct 06, 2008 5:29 am
schmauster920 wrote:i didnt know that they suck... ill probably pick up something decent later down the road, i dont want it to be too loud (till wastegate opens) less backpressure is good of course!
I have one on my integra lol, and it actaully doesn't sound that bad (for a honda). They are not that bad for n/a applications, but restrictive on turbo applications. Since you can weld and it's only temporary, i say go for it.
RIP Nate(480sx)...
Kfred
Postby schmauster920 » Mon Oct 06, 2008 7:02 pm
I had a magnaflow packed straight thru muffler on the truck before and it sounded like a civic with no exhaust... Thank you for your recommendation, once i get paid i will pick up a dynomax muffler and see what i think, i know im not going to get a quiet, free flowing muffler as it doesnt work like that :(
Postby schmauster920 » Tue Oct 07, 2008 10:41 pm
Last edited by schmauster920 on Tue Oct 07, 2008 10:45 pm, edited 2 times in total.
ok i mounted turbo and fired it up, looks like ill be doing the expected shady used turbo rebuild at home due to the oil spewing out around the turbine
Here it is clocked and oiled
heres a shot of my front end mod
I saw that on the streetfire redneck test video hahahaha
Project is on hold for a few weeks until i get paid
Postby schmauster920 » Sun Oct 12, 2008 9:12 pm
trying to get this thing going to see how bad it smokes... no ic for the time being, ill be running a small yellow 3.6 psi spring and 370s, the exhaust pipe came with that heat shield haha
we will see if the hardware store PVC couplers hold up at all hahahhahahaha.. Slownissan beaded the ends at least so we will see
Intake pipe will be longer and maf will be futher from the turbo, and i have a much larger K&N filter i will be using, so please dont flame me too badly lol
Postby schmauster920 » Sun Oct 12, 2008 9:43 pm
and 1 more so i can bump my junk for sale :D
S14 auto tranny anyone? :P
PreviousNext
Return to Hardbody KA-T's
Users browsing this forum: No registered users and 16 guests
