ka24de into 87 d21 power steering lines??
For those truckers!
screwnamez
Post by screwnamez » Mon Feb 10, 2014 10:20 pm
So like the title says, i've got an 87 d21, 4x4, with a ka24de out of a 95 240sx swapped in. I've worked out most of the kinks but i'm not sure where to start with the power steering lines and I was curious to see if any of you have already solved this problem. I was thinking I could go with some AN fittings but i'm not sure of the sizing or if I could adapt them onto the hardline that runs into the fitting that goes to the gearbox, haven't worked with AN before. Any input is appreciated, thanks alot
Re: ka24de into 87 d21 power steering lines??
Post by schmauster920 » Mon Oct 13, 2014 12:37 pm
Stainless steel braided hose and AN fittings would prob be the easiest good solution. Running hard lines would be nice, it would be a little extra work but will be a nicer solution in the long run.
