Page 1 of 1
Am I wiring my LS2 coils up properly
Posted: Sun Aug 28, 2011 12:53 pm
by drewssc400
I am using the MS II V3 board. Car is a 97 KA24DE. Using 4 coils for a wasted spark setup. I'm using this picture for reference and I'm not sure where (C) on the coil plug should go....
(A) on all 4 coils grounded to the manifold.
(B) from coils 1&4 will go to pin 36 on the DB37 connector.
(B) from coils 2&3 will go to pin 6 on the DB37 connector.
(C) ??????
(D) +12V from the fuel pump relay or other switched +12V source.
Thanks!
Posted: Sun Aug 28, 2011 1:01 pm
by drewssc400
I think I found my answer
(A) Goes to ground (intake manifold)
(B) Ground all 4 coils to pin 8 on DB37 connector
(C) Coils 1&4 to pin 36 on DB37 connector
(C) Coils 2&3 to pin 6 on DB37 connector
(D) +12V switched connection, probably from fuel pump relay
Thanks!
Re: Am I wiring my LS2 coils up properly
Posted: Sun Dec 13, 2015 8:38 pm
by ViperGT
lol that was it did you put in capacitors for noise reduction? or just wire it up? sorry to bring up old posts but im running through all these similar posts about ign coils making sure everyones ready to boost
Posted: Mon Dec 14, 2015 6:53 am
by supakat
I just wired mine up. I have thought about this but never had an issue with noise.
Posted: Mon Dec 14, 2015 6:32 pm
by ViperGT
sounds good
Posted: Tue Dec 15, 2015 1:12 pm
by Matt Cramer
supakat wrote:I just wired mine up. I have thought about this but never had an issue with noise.
It's usually not a big deal. A bigger deal is that I recommend grounding the LS1 coils to the cylinder head, separately from the ECU.
Posted: Tue Dec 15, 2015 1:29 pm
by supakat
Correct Matt. I have the stock harness for the coils and one is grounded to head and other to MS. I have my coils hooked up to a relay for 12v as well.
