So, the VSS input code seems to have greatly improved since the last time I looked at it. Has anyone got their VSS working directly into MS3 yet?
I am curious if it can support the gm t56/4lg now (few more pulses than the ka/vg vss). I wonder, Matt, did you try it on your chevy motor swap you did?
VSS input, has anyone here tried it yet?
- beercandrifter
- Matt Cramer
- KA-T.org Sponsor
Re: VSS input, has anyone here tried it yet?
I am using VSS input on my Chevy truck, bringing it in over CAN as I'm using a MicroSquirt to control the transmission. I'm not using direct input to the MS3, but that is supported too. I'd probably use an alternate second trigger input and bring the VSS in over the cam input VR conditioner.
