Page 1 of 1
Knock Detection
Posted: Tue May 12, 2015 3:01 pm
by FeArZ
I was looking at getting a PNP and learning to tune.
Are any of you using the knock detection on the Megasquirt to tune?
I was wondering this as I would be doing street tunes and I could log then adjust over and over.
Re: Knock Detection
Posted: Wed May 13, 2015 11:55 am
by Kill3rwill
I am not! I've been wanting to get it working myself! Maybe MattCramer can chime in on how this works on our mspnp2 systems. I know it is physically wired in through the wiring harness still, but the megamanual seemed rather vague. I don't know how I feel about simply turning the feature on and hoping it works.
Re: Knock Detection
Posted: Fri May 15, 2015 6:24 am
by Matt Cramer
There's two parts to the MSPNP knock circuit.
1. A headphone output that lets you listen to the filtered knock signal. It will show up as a high pitched almost beeping sound through the filter. Useful for tuning if your engine is knock limited.
2. The analog circuit that the ECU uses to pull timing. I recommend dialing it in so a conservative spark map won't make it trigger. Not something you'd want to use as a primary tuning tool, but it could help if you have something unexpected like a tank of bad gas...
Re: Knock Detection
Posted: Sun May 17, 2015 2:16 pm
by Kill3rwill
Anything to set up or adjust with either of these options? Or simply turn on and go. I was under the impression that knock sensors pick up and filter certain harmonics, so determining that harmonic seems a little scary. Like if I we had to induce knock to get it working
Re: Knock Detection
Posted: Tue May 19, 2015 10:50 am
by Matt Cramer
The frequency is physically set in the hardware. However, there are several trim pots inside the MSPNP you need to adjust. See the MSPNP manual for details:
http://www.megasquirtpnp.com/docs/mspnp ... &isModel=2
