Page 1 of 1
MS3 Pro install troubles
Posted: Wed Jul 01, 2015 8:08 pm
by Ruff Ryder 6
Hi all,
I have a 240sx that I am trying to get working on MS3 Pro. I have all the other connections made, but when I tried to crank the car I got no RPM. I am attempting to follow this writeup, but there is no mention of MS3 Pro on the page, and the settings change for each type of board and version of MS.
I added the 1k resistors that came with the MS3Pro. I switched the inputs around because I thought I may have had that backwards. Still can't get a consistent RPM signal. It shows up every now and then when cranking and I have gone through all the trigger wheel setting combinations. Sometimes it would show RPM when I let go of the key. I have attached my current .msq and a datalog. Need help because I am running out of time for a track event coming up. Any help would be appreciated. Thanks!
After doing a bit of reading, is it possible that the CAS is a 5v input with pullup not 12v? Currently feeding it 12v
Re: MS3 Pro install troubles
Posted: Tue Jul 07, 2015 7:51 am
by Matt Cramer
Try using a 5 volt pull up on the inputs, and make sure that neither CKP- nor CMP- are connected to anything.
