Peak and hold injector driver box
Postby Matt Cramer » Fri Aug 26, 2016 6:52 am
Need to run really big injectors? Like 225 to 550 lb/hr? Or have a set of old low-z injectors that you just don't want to swap out? We now offer an 8 channel peak and hold driver board for these low impedance injectors to make using them with an MS3-Pro or other MegaSquirt product a snap! The box itself is the proven Acceleronics Versaufeler; we tested it and were impressed with how it seemed to be nearly bulletproof and never ran hot. But we have added a unique twist to the ones we sell: They ship with our own harness color coded especially to match the MS3-Pro and MS3X injector wire color coding for easy installation with our engine management, with extra long wires to reduce the number of splices needed.
8 channel peak and hold driver board from DIYAutoTune
Matt Cramer
Return to DIYAutoTune
Users browsing this forum: No registered users and 9 guests
