S13 MSPNP2 aem wideband question
http://www.diyautotune.com
jesusno2
Post by jesusno2 » Mon Sep 05, 2016 6:44 pm
Hey S13 PNP guys can i hook my AEM wideband into the old S13 O2 sensor wire? Or do i have to connect via options port?
suck it!
Matt Cramer
Re: S13 MSPNP2 aem wideband question
Post by Matt Cramer » Thu Sep 08, 2016 6:53 am
You can either connect it to the options port or the O2 signal wire. Either way, you would use the analog signal output from the AEM, not the serial data.
SIL8D
Post by SIL8D » Sun Oct 02, 2016 5:16 pm
options port?
Matt Cramer
Post by Matt Cramer » Mon Oct 03, 2016 8:40 am
That's the 15 or 26 pin port on the back of the MSPNP next to the MAP sensor hose.
