DIY Emissions Removal SOHC
once u dump the charcoal canister there is going to be one line that is used for the gas can to vent. that line i would suggest you find a way to plumb it back into the intake if you don't want to smell the fumes.
I pulled my egr hose and capped it off. i also removed the solenoid that was on the top of the intake manifold.
thanks,
sid
thanks,
sid
Sid Nguyen
www.sidwin.com
95 Toyota Supra 680 RWHP
90 Nissan 240sx
01 Lexus GS300
01 Toyota Seq. Limited
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
can someone take a pic of the egr solenoid? i got the BPT off and capped all that stuff and i capped off the egr. I wish someone made egr block off plates like the do in the supra and then i could strip that guy off the intake and then plug the exhaust port too.
Thanks,
Sid
Thanks,
Sid
Sid Nguyen
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
- glacier985
sidwin wrote:can someone take a pic of the egr solenoid? i got the BPT off and capped all that stuff and i capped off the egr. I wish someone made egr block off plates like the do in the supra and then i could strip that guy off the intake and then plug the exhaust port too.
Thanks,
Sid
The EGR solenoid is about directly underneath the throttlebody if I remember correctly. It's hard to miss.
1990 240sx SE, 96K, ka24eT Time to Finish
- nelson240sx
they do make egr block off plates for the ka24e check ebay. I just unbolted the top half of the egr the big ugly part and use the smaller piece that bolts to the throttle body. I took a piece of sheet metal and stuck it in between the intake mani and the egr and bolted it back down. I did that because i am cheap but you could spend i think it is 20$ on ebay and buy one.
nelson240sx wrote:they do make egr block off plates for the ka24e check ebay. I just unbolted the top half of the egr the big ugly part and use the smaller piece that bolts to the throttle body. I took a piece of sheet metal and stuck it in between the intake mani and the egr and bolted it back down. I did that because i am cheap but you could spend i think it is 20$ on ebay and buy one.
I believe JGS sells a cap that screw into the exhaust mani to go along with the block off plate.
WHY ISNT THIS A STICKY YET?
Someone please confirm if most of this can be done on a KA24DE???
I realize that fiznat wrote the KA24DE removal one, but the pics are not there and his thread is reliant on the pics to know what is what...
Help!
Help!
4a. SCV actuator (not pictured), since the SCV solenoid was remove, this must be removed. This is located on the back of the intake manifold. It’s on the right side and controls the butterflies. Once it is removed you can do away with them as well. Each one is held in by two screws. Remove all four plates, the small screw in the middle of the intake and then pull the rod out. You can either have the rod holes welded shut or use JB weld.
So since I removed the SCV solenoid I have to remove this?? What happens if I don't??
Also is it neccessary to remove the butterflies as well??
- slydwayz
i've never really dealt with emissions and vaccuum lines much before, but i jumped into it removing my aiv case except for the metal hose, and the charcoal canister. now im confused about what i do with the 4 lines that come over the fan shroud, and metal vacuum line that goes all the way back to the firewall and then down somewhere, and the little black hose plug that comes out by the opening of the stock bottom side intake box. do i just plug it all off/ i was thinking about using one of the lines as a vacuum source for my bov and wastegate. ive no idea what to do with the rest. any help is greatly appreciated
<SOHCexy. Z32 stoppers. 12 psi t25. Godspeed ic. E-mance tune. 460cc dsm's. Arias pistons. etc. AND ive worked on fixing its many problems more days than Ive actually driven it!
- glacier985
Ok need help. Got the TB off fine (the top part is the throttle body right?)
I'm trying to take the rest of the intake manifold off...took the 4 bolts off on top. The 2 bolts mounted on the black bracket. Are there anymore I need to get? I saw some pics and looks like there are 2 more way underneath. How do you get to those? Help please.
Thanks
Kingston
Thanks
Kingston
theres actaully 3 more bolts
one is close to the powersteering pump bracket
the other two is directly underneath the fuel rail mounting points
its kinda camoflauged with the manifold
i thought it was underneath too but yea kinda tricky that one
one question for you guys
if i didnt run the coolant lines to the intake plenum or throttel body
will that affect idle in anyway if i start it up in cold weather
- merlin240s13
k to start off....
there are a number of people on here that be can dicks about questions like this...
not that you're doing anything wrong by asking but try this out.... there is a tab above your alias that says search consider it your best friend. it works like your normal search engine, type in what you want to know, and start reading. it works alot easier for you (not having to wait for replies), and everyone else (not having to repeat everything 100 times)! also I think you will learn alot quicker if you do it this way, as it works well for gathering a lot of general information that you need if you are new to alot of this.
if you type "emission removal" into this search you will find the "DOHC emission removal mystery revealed" thread this is the prominent thread. it has ALOT of useful information in it but the pictures are gone so its kind of a pain in the ass. So download a FSM (factory service manual) online for your chassis (also a must if you are a DIY'r) and use the emissions diagram in that to get the feel on what they are talking about. there are pictures later on in the thread too that will help.
welcome to KA-T.org
remember search, search, search, and if you can't find anything typing in varying definitive keywords then ask (trust me you'll learn alot more in a shorter timespan this way, think of it as an instant respond, and don't be afraid to read/scan a lot).
welcome to KA-T.org
Has anyone had any codes come up when removing the EGR, if so, anyone wire up a resistor to fool the egr and does it wor??caoboy wrote:for california cars, i believe you can wire up a resistor to fool the egr. even though im in california, i have a federal car (no CEL in the gauge cluster) and i think i could get away without having to put in resistors.
Thanks,
Bry
I am going to remove that stuff this weekend. I wounder how it will run once the engine is turboed?
www.WestEndTuners.com
2011 Yamaha R6 - Summer ride
2003 Chevy Blazer 4x4 - Daily Driver
1999 Integra - Track car
- merlin240s13
After the emissions removal, if you do it correctly, your engine should perform normally (if not better from what I've heard). Although after turboing (which causes more blowby) you should aim your concentration at the PCV system, there are numerous write-ups posted but I think you would gain a better prospective from looking at stock turboed engine in your power range and general operation, i.e. flat-four, inline four, inline six, V.E. ?...
If you tune it correctly you should have good overall emissions anyway. Visual inspections are a different story...
- iamanonymous
process of elimination....
removed everything in the write up except the parts pictured to keep. did an extensive overhaul to the engine, added turbo, etc, all at the same time. just want to make sure everyone is experiencing NO power loss, rough idling, or excessive popping through exhaust after emissions removal.
thanks
thanks
boosting
When I first got my car, I was cleaning of the engine, and broke some wires that went to what I believe to be the pressure regulator solenoid valve. It's located on the back of the valve cover. There are two valves back their with different functions, and it would be the one towards the pass. side. About a week or so later, I was driving home from work, and my exhaust was ultra loud, I had a significant loss in power, and my car had trouble idling. Me and my dad rewired the plug and connected it, and it has happened since.
So when I first came across this thread I was a bit skeptical to put it into practice. I have not yet tried all this, but to be honest it isn't necessary, and it could cause potential problems. However, if one of these valves were to stop functioning, I would look into removing it, not replacing it.
Make sure your timing is correct, and since you are boosting, I don't have much more to say.
- syncline803
- undesiredshoe
