o&j cam lifters video?
does anyone have the cam and lifters from o&j if so can i get a video clip im just wondering what they are supposed to sound like because something about mine just seems off when its running it seems like its backfireing and running kinda ruff but it is a stage 2 cam so just looking to compare it to something before i make my next move
Static compression is different the dynamic compression. A static compression test is just used to determine if each of the cylinders are sealing properly. You are really only looking for the same reading between cylinders. This cam isn't really efficient below 2000rpms, thats why your readings are lower.
SOHC S-14...
i noticed you and gladman had a dicussion about cams, i like the torque with the stock cam i dont plan to be turbo for a while do you think i will still enjoy driving the car na with that o&j cam or should i just stick with the stock cam i like to auto cross my car and drift sometimes im not really into drag racing
- Jordan Gladman
So no one has a video of their car idling with solid lifters?
Drift9- check the FS link in my sig, im selling my colt C404 cam. Sounds like what you might want.
Last edited by Jordan Gladman on Thu Sep 09, 2010 10:56 am, edited 1 time in total.
lol, I can show you what it sounds like without lifters and a hyd cam from them. The lifters are not happy.
Finally 300hp
Finally 300hp
