Ok so my 240 fired up after a 8 month transformation mind u i had it fired without the turbo on like a month ago! So she idles but rough as hell and if i touch the gas it acts as if im either flodding or hitting fuel cut so im clueless now heres what i have fuel wise,
450cc injectors
aeromotive fpr 40lbs of fuel right now? ( is this too much what should i run)
stock maf
currently no tune or piggy back nothing!
So do you think with the info above it is runing rich or lean and now heres the kicker i thought for sure it was running rich but it stalled after a min of running and i went to fire it again and i had to push the gas to the floor for it to fire again then its back to the same prob THANKS IN ADVANCE!
ka24e-t finnaly running questions now!
Boost gets you laid
- Jordan Gladman
Its running rich as heck. You wont be able to drive around with 450s and a stock maf without any tuning what so ever. Just wont happen. You're probably idling with 5:1 AF's and washing out your cylinders. Dont run the car until you get atleast an S-AFC and wideband.
