SOHC Turbo Build For Dummies
Lisa-Adam
Post by Lisa-Adam » Thu May 22, 2008 2:45 am
The Ford Motor Company introduced their single overhead cam (SOHC) engine in 1970, and since then they have been installing it in close on a million vehicles a year. This means that by now there are a lot of these engines around. In Europe, this engine fulfills a number of duties ranging from everyday workhorse requirements to the higher performance needs of Ford's more sporting vehicles like the RS Escort.
Get information about Gary Winnick from The New York Times.
wcbjr
Post by wcbjr » Thu May 22, 2008 7:08 am
What the hell is that?
wcbjr
Post by wcbjr » Thu May 22, 2008 7:19 am
bloodsport wrote:p.s. the fc turbo injectors are cheaper than the n/a injecters thru partsamerca.com 8)
How about these?
http://cgi.ebay.com/ebaymotors/4-Mazda- ... QQtcZphoto
bloodsport
Post by bloodsport » Sun Jun 01, 2008 3:35 pm
i just bought 10k resisistors, the also had just the tens but the guy said that was to high for a car. sooooo did i get the right or the wrong resistors
240tuned91
Post by 240tuned91 » Sat Nov 22, 2008 6:54 pm
why is this post just for sohc why not dohc or does it work for both. im assuming both?
blaisearts
Post by blaisearts » Tue Nov 25, 2008 6:47 pm
240tuned91 wrote:why is this post just for sohc why not dohc or does it work for both. im assuming both?
Most likely because this post is in the SOHC KA-T forum. Haven't looked just now but I'm assuming the same type of thread is in the DOHC KA-T forum too.
:edit: That would actually be in the KA-T Basic forum.
Beginning the research phase for building a KAZ24ER
sil-kat
Post by sil-kat » Fri May 14, 2010 12:40 pm
Im using pulsar 440cc injectors on my ka24et. its tuned for it but i dont think im getting fuel (wont start unless quick start is sprayed in the intake) would those need a resistor box
meme2105
Post by meme2105 » Thu Jul 01, 2010 9:58 pm
hey wuts up guys. ok, im new to turbo and im currently buying parts to turbo my car. now i purchased a set of sr20det 370cc injectors. will these work on the sohc? im curious because on www.240sxforums.com someone mentioned that it will not work. now, i can get my hands on the 550cc injectors from the t2 rx7's if need be? i just want to know if the ones i have will work.
Q45 Brake Upgrade-kevlar brake pads
Godspeed Swaybar-front
ebay strut bar-front
Tokico HP-front
KYB GR2-rear
Ksport GT springs
Jordan Gladman
Post by Jordan Gladman » Fri Jul 02, 2010 7:51 am
They wont work, you need top feed injectors.
meme2105
Post by meme2105 » Fri Jul 02, 2010 11:24 am
ok, thanx. so the 550cc rx7 high impedance injectors are a straight drop in? cause if it is, im going to pick them up from my friend and sell these injectors..
Tokico HP-front
KYB GR2-rear
Ksport GT springs
Jordan Gladman
Post by Jordan Gladman » Fri Jul 02, 2010 11:46 am
Yeah, you just have to get smaller o-rings.
meme2105
Post by meme2105 » Sun Jul 04, 2010 10:06 am
i also found a good deal on the dsm 450 injectors. now i read on here that i need 10k resistors? idk, how difficult is it to apply these?
Tokico HP-front
KYB GR2-rear
Ksport GT springs
pwjm
Post by pwjm » Sun Jul 04, 2010 2:45 pm
AFAIK you just wire a resistor inline on each injector harness... So pretty darn easy.
Melenhorst
Post by Melenhorst » Thu Sep 30, 2010 7:06 pm
for the 230-240 mark, with a stock t25, and 450cc injectors, an intercooler, is greddy emanage and apexi safc really necessary?
13waynegarcia
Post by 13waynegarcia » Thu Sep 30, 2010 9:26 pm
You will need something to control fuel. You will at least need an SAFC and some timing retard. I have the same turbo but i haven't put it all together yet. You should ask this question in the KA-T basic section. But like i said you definitely need something to control fuel and the tuned ecu is a big plus, for any large type of hp you need to have a tuned ecu.
aron0128451
Post by aron0128451 » Sat Apr 30, 2011 7:00 am
MakotoS13 wrote:completely unecessary.
i don't have ANY computers other than the STOCK computer and i'm running a T3/T04E turbo with 550cc injectors.
so im looking at adding a turbo to the ka-e im swapping into my 87 hb 4x4. ive got a t25 from an eclipse. im not looking to do anything over 6-8 lbs as this is going to be a daily driven truck. can i keep the stock ka ECM with bigger injectors? and on the list of parts, is the apexi safc2 and the greddy emanage 100% needed? im doing this build on a budget, but if i absolutely have to have this, then im ok with it.
71ka510
Post by 71ka510 » Mon Mar 05, 2012 11:30 am
sure wish the pictures still worked....... :(
Ikera
Post by Ikera » Thu Oct 18, 2012 11:40 am
it would be nice if the approximate boost level was stated too
Post by supakat » Thu Oct 18, 2012 4:32 pm
Boost level does not mean anything. LBs/min is the accurate way but most people won't understand this. 10psi with a T2 is different than 10psi with a T4.
