Victor Reinz Nitroseal Headgasket
Was just wondering if any of the SOHC guys not wanting to cut up a Cometic had decided to run a Victor Reinz Head Gasket instead of a felpro. If so, would you recommend? or just go with the rubber felpro?
Re: Victor Reinz Nitroseal Headgasket
Saxy, where did you find a Victor Reinz head gasket for the ka? ...I've searched with no luck.I'm curious about this being an alternative.
rockauto.com appears to offer one. I'm searching under 1990 240sx as that's what model my KA is from....so it should be for the SOHC. Worth looking into
Ordered a VR intake manifold gasket set from napa , needless to say I did not use it. It was the first metal int mani gasket I've seen(ka) and I was stoked till it was the wrong size and they didnt actually have one to fit the ka
I've had good luck with the brand when it comes to a roll of gasket sheets. I'd go fel-pro if I was in your shoes.
I know OandJ offers a metal intake mani gasket. I was just browsing head gaskets and ran across this one.
