What's up guys I recently got my car tuned and I'm not too happy with the results. Its a fully built sohc ka with 7.9:1cr ,godspeed 50trim 63ar turbo , 800cc deatchwerks injectors ,38mm wastegate ,megasquirt PnP ecu ,map converted .
Here's the thing. I had my stock motor @15psi it made 325whp 309wtq and this built motor makes 339whp 318wtq @18psi.the tuner said he wont tune for more than 18psi on pump gas and it wont make any more power "airflow is maxxed out". But I feel like It should make more power .
Here's some timing maps and other shots of the tune . tell me what you guys think. Thanks
Ka24et timing maps/tune
89 Ka24e-t
completely stock
49k miles
550cc injectors
z32maf
GSP.50 trim
38mm WG
10 psi
260wtq
completely stock
49k miles
550cc injectors
z32maf
GSP.50 trim
38mm WG
10 psi
260wtq
Re: Ka24et timing maps/tune
I'm probably not much help here, as I am just about to boost sohc for the first time. However I have been tuning on DSM's for a very long time. I know on those speed density is a good answer for air flow issues, just not sure if any options exist for these setups as of yet.
