Got an rb25 competition clutch flywheel. Anyone know what 350z clutch will work and won't work. I.e os giken 350z clutch with the rb25 flywheel on a ka24e?
Do the ka24 flywheel bolts work with the rb25 flywheel?
Thanks in advance
Possible clutch combinations?
Last edited by LuxExperience on Fri Jul 17, 2015 12:42 am, edited 1 time in total.
Re: 350z clutch?
I do not understand about the stories I want to ask you to help me.
Re: 350z clutch?
Anyway for other KA owners looking to use other set ups, here's what i've learned.
Rb20 flywheel + Rb20 clutch - Works
Rb25 flywheel + Rb25 clutch - Works
Rb26 flywheel (early RBs only! push type not pull) + 350z clutch - Works
D21 flywheel + clutch - Works
Sr20 flywheel + Ka24 clutch - Does not work (SR parts are not interchangeable)
Ka24 flywheel + Sr20 clutch - Does not work (SR parts are not interchangeable)
Ca18 flywheel + ka24 clutch - Does not work (CA parts are not interchangeable)
Ka24 flywheel + ca18 clutch - Does not work (CA parts are not interchangeable)
Rb25 flywheel + 300zx NA clutch - Works
Rb26 flywheel (early RBs only) + 300zx NA clutch - Works
All Rb clutch and flywheel combinations are 240mm with the exception of RB26 flywheel+350z clutch which is 250mm
