Question about Greddy E-Manage wiring
kalisto2002
Post by kalisto2002 »
So I was reading over my install material and have been searching around online for the last few days.
In the manual it says you are supposed to connect your wiring for the injectors to 4 injector power wires and one injector common ground.
However in the case of the single cam KA it has switched ground injectors with a common power instead.
How would i wire that in. I wanted to get some bigger injectors for my turbo setup but can't at the moment because
no way to tune fuel.
Any help would be appreciated.
91D21KaT
Re: Question about Greddy E-Manage wiring
Post by 91D21KaT »
i have he same problem what was your fix?
