LS1 Coil conversion
http://www.bremotorsports.com
Tex Blackwell
LS1 Coil conversion
Post by Tex Blackwell » Sun Jan 11, 2009 10:09 am
Hows it going guys, I'm super busy but a couple of people have been asking for pics on the progress of the ls1 truck coil conversion...here is a pic of them mounted..
AEM
LS1 Truck "smart" coils
GM 3 bar
Thats it so far...
Any questions please feel free to ask!
Tex Blackwell
VP B.R.E. Motorsports, Inc.
www.BREMotorsports.com
Blackwell Race Engines
(980) 521-2224
2007 NOPI NDRA Pro4 Cylinder Champion
http://www.myspace.com/mblackwelljr
tensecondrunr
Post by tensecondrunr » Sat Jan 31, 2009 12:28 pm
i want the ls coils so so so bad, but i'm quite confused as how to go about doing it..besides the coils themselves what else ignition wise has to be changed? also wtf do you do wth the distributor? Any answers you could give me would be much appreciated.
95 240sx KA with the T! on the way..
"Truthful words are not beautiful; Beautiful words are not truthful. Good words are not persuasive; Persuasive words are not good."Lao Tzu
Tex Blackwell
Post by Tex Blackwell » Tue Feb 10, 2009 11:39 pm
tensecondrunr wrote:i want the ls coils so so so bad, but i'm quite confused as how to go about doing it..besides the coils themselves what else ignition wise has to be changed? also wtf do you do wth the distributor? Any answers you could give me would be much appreciated.
You will need an engine management that supports multiple ignition outputs. (AEM)
You can use the inernals of the distributor. You will no longer use the spark plug wires off the cap or the cap itself. Simply remove the cap and rotor button.
Tex Blackwell
(980) 521-2224
that1guy
Post by that1guy » Sat Feb 14, 2009 9:08 am
What outputs would you use in the aem and what all has to be changed in the calibations. I am also running with an AEM EMS and was thinking about doing this.
that1guy
Post by that1guy » Sat Feb 14, 2009 9:11 am
Also is the wiring just simply +/-/signal, thanks in advance.
Mark Washington
Post by Mark Washington » Tue May 25, 2010 2:22 am
Some people never answer. I am just searching trying to see what I have to do to
not run a cap and rotor on my E. Just brousing but didn't want to cludder the
forum with stupid questions so Ill be looking into the best way to do this.
I am not in any hury to run 4 coils cause I just hardwired my MSD one do
at least I touched on the subject for now. Knowledge never hurt though.
速い速い シルビア ターボターボ
Its not the size of the turbo,Its how you spool it.
Tex Blackwell
Post by Tex Blackwell » Sat May 29, 2010 10:50 pm
You will have to run an AEM ems.
-Route the individual coil signal wires from the AEM to the coils
-Distribute power & ground wires for the coils
As for the distributor: you can just remove the distributor cap and wires. You also do not need to run the plug that has two wires on your distributor
Tex Blackwell
(980) 521-2224
Tex Blackwell
Post by Tex Blackwell » Sat May 29, 2010 10:52 pm
Mark Washington wrote:Some people never answer. I am just searching trying to see what I have to do to
Also, yes you will have to make some changes to the calibration in order for the coils to work.
Tex Blackwell
(980) 521-2224
