CNC Ported KA24 heads
- KA-T.org Sponsor
BRE has had the KA24 cylinder heads available. At anytime, quick turn around time, specific application available.
More info soon.
Please ask any questions.
More info soon.
Tex Blackwell
VP B.R.E. Motorsports, Inc.
www.BREMotorsports.com
Blackwell Race Engines
(980) 521-2224
2007 NOPI NDRA Pro4 Cylinder Champion
http://www.myspace.com/mblackwelljr
(980) 521-2224
could you guys tear it down and rebuild it as well? also, are you a distributor for brian crower/supertech/etc so someone could get their head ported then rebuilt with upgraded components? as silverstreek mentioned, this would probably work into the different levels of porting. just ideas. i think this is a great service.
also can you guys get ahold of the ferra(spelling?) 1mm oversized valves with retainers/springs/ect.irritatedmax wrote:could you guys tear it down and rebuild it as well? also, are you a distributor for brian crower/supertech/etc so someone could get their head ported then rebuilt with upgraded components? as silverstreek mentioned, this would probably work into the different levels of porting. just ideas. i think this is a great service.
Too much to list.
KA26DE-T in the making. BC Stroker Kit, Kelford 272's, borg warner s258 (18-20 psi)9.5 to 1 compression, Full Race Twin Scroll, and a few more goodies.....
- nissanfanatic
- KA-T.org Sponsor
Yes we do have a couple stages of porting...the best port will probably run you around the low $1000 range.silverstreek wrote:obviously price is a question. are there different levels of headwork available? i wouldn't need anything extreme, nor would i wanna pay a hefty $2000 price tag just for a bit of porting and polishing and a valve job, like most places want.
Tex Blackwell
(980) 521-2224
(980) 521-2224
- KA-T.org Sponsor
Yes we can tear down/clean/inspect/port/assembly etc...irritatedmax wrote:could you guys tear it down and rebuild it as well? also, are you a distributor for brian crower/supertech/etc so someone could get their head ported then rebuilt with upgraded components? as silverstreek mentioned, this would probably work into the different levels of porting. just ideas. i think this is a great service.
We are a distributor for all the major components.
Thanks,
Tex Blackwell
(980) 521-2224
(980) 521-2224
- KA-T.org Sponsor
Ferrea, yep, these heads seem to flow better with the oversized setup.Spud5251 wrote:also can you guys get ahold of the ferra(spelling?) 1mm oversized valves with retainers/springs/ect.irritatedmax wrote:could you guys tear it down and rebuild it as well? also, are you a distributor for brian crower/supertech/etc so someone could get their head ported then rebuilt with upgraded components? as silverstreek mentioned, this would probably work into the different levels of porting. just ideas. i think this is a great service.
Tex Blackwell
(980) 521-2224
(980) 521-2224
cool, well i may look into having you do some mild porting/polishing and a 3 or 5 angle valve job on my ka24de head. do you guys have a flow bench as well? if so, what brand?Tex Blackwell wrote:Yes we do have a couple stages of porting...the best port will probably run you around the low $1000 range.silverstreek wrote:obviously price is a question. are there different levels of headwork available? i wouldn't need anything extreme, nor would i wanna pay a hefty $2000 price tag just for a bit of porting and polishing and a valve job, like most places want.
- KA-T.org Sponsor
We use a superflow
Tex Blackwell
(980) 521-2224
(980) 521-2224
seen a built head at bre this weeekned.. looked like the hotness... 1mm over, 5angle nastyness...
all i can say is i seen the doner heads that were cut to see where the most pwoer was made.. i think they sacraficed 4,5 heads to get the cnc port/program straight...
i havn't seen any other companies offer flow specs...
it is no back yard setup or some guy sitting there with a dremel.. there is real technology put into these heads(cnc port) 6 months to a year were spent lookingat ways to help the flow.. i wouldnt be giving up my flow specs all that easy either.
for the price bre is offering them at they cant be beat.. and for a street car the head is overkill... they build full on drag cars.. you are getting full on drag car built head..
s14.5 soon to be turbo and show quality
yeah....telling us the # isnt exactally giving away any secrets. would def promote sales
- DRFTPUNK
Maybe I'm just a noob but if it's all CNC done why the difference in price for a mild p+p to a badass one? and why charge more? If it's just a machine doing it I dont see why it should cost more, just have them all badass P+P and the service cheap and crush all the competition?
/sometimes I just dont get capitalism lol...
supakat wrote:I will tell you one thing, if I had to choose between stretched tires and stretched pu$$y, I would go with tires.
S14 Zenki, GT35, 80lb injectors, RS Enthalpy tune, Eagle/ Wiseco 8.8/1.
RIP 480sx
