s14 adaptor
http://www.rs-enthalpy.com
datsunissan
s14 adaptor
Post by datsunissan »
i heard that all enthalpy ecus are s13 and that id need an adaptor for my 95...is this true? and how much are they? or preferably does anybody have one for sale?
Super Coupe
Post by Super Coupe »
I believe he can tune certain s14 ecu's now. Call him.
But yes if you use a s13 ecu you will need an adapter harness. You can purchase one through him for $150 if you buy a tune. $200 if you buy it separately.
Zumin
Re: s14 adaptor
Post by Zumin »
The s14 ecu has apparently proven to be problematic. I just installed the s13 ecu/ harness adapter into my 97, worked perfectly. The s13 ecu is more "rom friendly". I removed my rear o2, all sensors that aren't needed for basic engine operations. Martin was areal help. Also, check engine light still works
T28, n62, 550cc, runs perfect.
Re: s14 adaptor
Post by sdaigle240 »
95 ECUs shouldnt be a problem, 96 and up is no dice.
s14tilo
Re: s14 adaptor
Post by s14tilo »
They now support s14 kouki ecus as well. According to their homepage.
