top mount set up downpipe
www.godspeedproject.com
93sr20det
Post by 93sr20det » Wed Feb 13, 2013 8:31 am
I know this is a KA-T forum, but I was wondering if anyone had tried the topmount set up down pipe and if anyone had clearance issues or any pictures of it installed. They list 2 on their website, one that is for a top mount set up with 2 oxygen sensor bungs, and then there is one that comes with an sr20 cast manifold that has a flex section. I sent them an email but no one responded. Any help on this would be appreciated guys.
sohc-t with cracked pistons, gotta love it...
AFKOUKI
Post by AFKOUKI » Wed Feb 13, 2013 10:41 am
I bought one, and didn't end up using it.
Mounted on the turbo for pics, but no use. Its the dp with o2 bung and flex section. Ill sell that and the dumptube for $100 shipped if you're interested. Just shoot me a pm
93sr20det
Post by 93sr20det » Wed Feb 13, 2013 12:02 pm
Man that would be awesome, do you have any pictures of the clearance on the car by chance, or did u never mount it in the car?
AFKOUKI
Post by AFKOUKI » Wed Feb 13, 2013 2:18 pm
Sorry, never mounted in the car. pm'd
Post by shift_down » Wed Feb 13, 2013 5:44 pm
That's the same dp I have, clearance is perfect
93sr20det
Post by 93sr20det » Thu Feb 14, 2013 10:43 am
shift_down wrote:That's the same dp I have, clearance is perfect
Which manifold are you using? Is it tubular or cast?
Post by supakat » Thu Feb 14, 2013 10:50 am
He is using this but the tubular has the same placement if you bought the cheap one.
viewtopic.php?t=58991&highlight=
93sr20det
Post by 93sr20det » Thu Feb 14, 2013 12:40 pm
supakat wrote:He is using this but the tubular has the same placement if you bought the cheap one.
Huh? I bought a cast ISIS that's identical to the cast godspeed... the dp i had would work with my last manifold, but will not work with this one. That's why I'm asking which manifold he's using
Post by supakat » Thu Feb 14, 2013 12:46 pm
Turbular
Cast
I guess you can say there is a slight tilt of the flange between the two. They are close though.
93sr20det
Post by 93sr20det » Thu Feb 14, 2013 3:59 pm
That's what I'm worried about... some places are notorious for not checking fitment. I'm hoping this isn't the case bc I already paid for it
Otherwise I'm gonna have two useless down pipes
Post by supakat » Thu Feb 14, 2013 3:59 pm
If so, just make one out of two.
icantdrift
Post by icantdrift » Mon Feb 25, 2013 10:43 pm
Subscribed, because I'm in the same boat. I have that exact tubular manifold, and have no idea what turbo outlet/downpipe combo I need to connect it to my test pipe. :oops:
93sr20det
Post by 93sr20det » Tue Feb 26, 2013 8:04 am
Well mine isn't working, several factors could be different for you. I'm using this on an sr, manifold is almost identical though but mine is cast. One problem i am having is there is no brake booster clearance. I'm hopefully going to solve this by either loosening mounts and moving motor a bit, or using a sentra master cylinder. The other clearance issue I'm having is that the downpipe is rubbing the steering shaft. Maybe that will clear up if the motor is moved any
Post by sdaigle240 » Tue Feb 26, 2013 11:07 am
get an s14 5speed non abs brake booster. worst case u gotta redo the DP, theres def room for a 3" to clear on all sides though.
Post by shift_down » Tue Feb 26, 2013 11:50 am
I use that fastway log mani, emusa dp, emusa midpipe, emusa straightpipe, ebay cat back. Fit PERFECTLY.
Ill get pics up once I bolt everthing back together, but this is all I found
93sr20det
Post by 93sr20det » Tue Feb 26, 2013 12:01 pm
Thats a different manifold than mine... if the flange is not turned that 1/4 of an inch or however much its angled, it will not fit... if its a KA manifold you don't have to worry because all those looked to be angled slightly
icantdrift
Post by icantdrift » Tue Feb 26, 2013 6:32 pm
shift_down wrote:I use that fastway log mani, emusa dp, emusa midpipe, emusa straightpipe, ebay cat back. Fit PERFECTLY.
Links to emusa dp and midpipe? :D
