GodSpeed Type RS BOV
Posted: Sat Mar 02, 2013 2:26 pm
Ok so I needed a BOV and decided to go with the godspeed Type RS.
I opened it up and took out all the contents, and this is what was included:
BOV
2 recirculation fittings
Aluminum bung
Gaskets
2 T fittings
Vac hose
Hardware
Everything looked nice until I found that one of the hex screws holding the blow off valve closed was not fully tightened, no big deal, just be careful:
The blow off valve outlet come with an o-ring attached to it, and it screws off so that you may be able to attach a recirc fitting:
Here is the BOV taken apart, you can kind of see the casting in the outlet is rough,. Expected from a replica, but I don't see how that will have any negative outcome:
It came with two springs, one stronger than the other. A spring holder was included and the diaphragm looked very good:
The diaphragm looks nice and it feels very tough:
You can see the casting of the outlet is a bit rough:
Overall, I think its a good piece and Ill post my experiences of how well it works once I get it on.
BOV
Aluminum bung
Gaskets
2 T fittings
Vac hose
Hardware
