Alright, so, a day or so ago I stuck a piece of paper in between the nut and bolt (one of the nuts/bolts that I had dabbed off the excess and used a heat gun to help dry. The paper soaked the green 290 loctite right up. This stuff is STILL WET about 2 weeks later. The only thing I can think of is that the box and the loctite was warm when the mail was delivered, so maybe this spoiled it?
So, I'm kind of stuck on what to do. All the bolts/nuts (160) have been torqued in three stages in a quarterly fashion (
like one would torque a 4 lug wheel, but then moving one bolt to the right after each 4-set...a serious PITA to do, making sure the nut doesnt spin and the bolt heads are not damaged by the socket). The nuts are "locking-type" nuts (see pic below). Half of me wants to just soak up whatever amount of loctite that will come off and then just put some new blue loctite around the top of the nut and let that seep into the threads, but then the other half of me says just take them apart and re do it, but this time test the locking compound first.
I dunno what do you guys and girls think? What would you do?
