Water in engine?
Posted: Tue Sep 06, 2011 6:06 pm
It wouldn't let me post this in the tech section so I am going to put it here. Sorry about this but I really need some advice..
I am currently working on my wife's 91 240 and I am having some major trouble.
It blew a head gasket about a month ago and I replaced the head gasket with new head bolts, resurfaced, and all new gaskets. I also torqued the bolts to proper spec.
Since then I am having some major problems.....
I am getting water in my engine block but no oil in the water. The motor has compression on all cylinders, and when I removed the Intake mani to check and see if it was properly sealed with the gasket it was dry and looked as though it was sealed.
I found milky oil in the throttle body and it was getting on the plugs.
It has a brand new head gasket, and the intake mani was properly sealed. so my questions is what else could be causing the water to get into the engine.
