My KA-T coupe
- Mark Washington
My KA-T coupe
Just a I-phone shot nothin spectacular Im just trying to work a few bugs out before
TD
TD
- Mark Washington
- Mark Washington
Thank you very much, that makes all the work well worth it when you can feather the throttle and smoke the tires with a hair of ajustment. I am just getting used to the Higher boost levels. It surprizes me every time. I had power in mind when building this and had big plans for later but I dont know what to do with the power I have in the conditions above yet. That was my first time around in about a year so after TD on the 30th I should have the car down again.
good **** MW nice to see it in action.
- Mark Washington
Oh yeah thats with a passenger first time back out and there was a van in my clipping point so I had to puss out.
I have had this car for a very long time and it was a stock automatic when I got it.
this is my 5th/6 S13 not including the one S14 I crashed and forgot about.
I like S13's due to the nimbleness and availability and also the coilovers on my car have been on two prior to the coupe. I also prefer coupes unless its a caged hatch then I dont care. The hatch are way easy to strip the sound dedoning and seamweld the coupe was a little cramped but well worth it. The coupe drives like a hatck does if you buy a strut bar and take the hatch off stock IMO and on a built level none of this matters cause alignment has more to do with a nice angle than how many ponies you can squeeze out of a litle 4 banger. I spent way too much time and money building and not any seat time so I am very excited for Thunderhill I hope it stays running OK for the event Im not driving it till it goes on the trailer.
- Mark Washington
This is my car a while ago before widebody and Turbo. That was with 560cc injectors N60
pacesetter header and rebuilt motor with R4 cam and the same CP's 9:1 DE 8:1 for me. I knew the car was going to be boosted when I got it and this was my 5th s13 when I got it.
I have been running the same built bottom end for a while and the stock rods wont through and it would be a waste to put the new block it for 0 power gains other than the fact that I dont have to worry about throwing a rod and I will have the option to run over 15 psi/1 bar. As many of you have heard I have a New block I have fully built but I need a few little things before I finish. If this one goes and it feels like it should but it has the same CR (125psi) after 3 felpro HG jobs "not cause it was blown but cause the head had to come off for othr reasons"
The new block wil handle the RPM's its begging to hit but Its to fragile for that now.
I dont need more boost than 14-15 for now and the longer I wait just like with the tires
the newer it will be.
http://www.youtube.com/watch?v=L3-BHAqSa2g
This was over 3 years ago I have some history with this car and like it very much.
- Mark Washington
This is the Guy who shot the first vid in his KA24E powered coupe
He has a 1000HP 240Z and got rid of the 240sx to make room for the Tundra 2x
to tow with. His tows way better than my 4x4 Tacoma but swung what you brung right?
http://www.youtube.com/watch?v=9R0QvOcc ... re=related
Just so some people can stop it with the "I need a turbo to drift!!" even though it does help a little
you troll too hard.
24 post of complete garbage, i believe you meant to type in zilvia.net in your browser. if your here to learn then stfu and stop **** where you eat.
- wannaboost?
- Mark Washington
This after my TB Boot broke and I couldn't hit much boost without it exploding.
http://www.youtube.com/watch?v=7rToiIX4 ... ture=feedu
速い速い シルビア ターボターボ
- Mark Washington
