Single cam on the street...
NA or Forced Induction 240 videos ONLY here.
Jordan Gladman
Post by Jordan Gladman » Mon Sep 06, 2010 1:01 pm
Couple pulls. (ignore the wideband, i had just blown the factory 02 out of the bung when I hit rev limit so I was sucking wind)
http://www.streetfire.net/video/sohc-ka24et_2056867.htm
http://www.streetfire.net/video/sohc-ka24et_2056869.htm
http://www.streetfire.net/video/sohc-ka24et_2056873.htm
Not bad for 1 hand on the camera and wheel at the same time! :shock:
pwjm
Post by pwjm » Mon Sep 06, 2010 5:38 pm
:bowdown: :bowdown: :bowdown:
Niclas_AB
Post by Niclas_AB » Wed Oct 06, 2010 10:45 am
Nice! :D What boost are you runing and what power do you think you're at? is that third and 4th gear in the first vid? You seem to have a slightly different gearing than me :)
Jordan Gladman
Post by Jordan Gladman » Wed Oct 06, 2010 11:34 am
Its 2nd/3rd gear.
These vids were with my first cam shaft, the cam i'm running now is quite a bit more aggressive and opened up the top end like a can of worms. I was running 25psi on my JDM sport knock off GT35, but I've switched to the T3 super 60-1. I'll probably run it at 20psi and hoping to be just over 400whp.
I would imagine our gearing is the same, I just have a different tach. I dont usually rev my SOHC much past 7000.
Niclas_AB
Post by Niclas_AB » Wed Oct 06, 2010 1:42 pm
Ah, ok. I'm running a manual s14 diff with a gear ratio of 3.692, our gearboxes are probably the same thou. But when I look at your speedo your doing about 140mph in third gear :? or wait, are the big numbers on your speedo km/h and the small ones that you really can't se mph?
Either way, that is one cool s13 sohc, love your mustang rims! wish that I could find a way to ship them cheap to Sweden :roll:
Jordan Gladman
Post by Jordan Gladman » Wed Oct 06, 2010 2:36 pm
Take a flight over... You could probably get 2 in each suit case.
My speedo is KM/H - Canada. :wink:
s13grady
Post by s13grady » Wed Oct 06, 2010 10:07 pm
impressive once again.
92 s13 ka24det sc61 project.
street trim sleeper
Niclas_AB
Post by Niclas_AB » Wed Oct 06, 2010 10:15 pm
ah, then it makes sense :lol:
