Found limits of H1C
efeezi
Found limits of H1C
Post by efeezi »
Went to the dyno today and found the limit of the H1C. 15psi hit 392, cranked it up to 25psi and only made 411 but had a **** more torque. Torque started early and carried pretty far, it almost feels V8'ish. This is also with a 50/50 mix of E85 and 91 piss.
Kinda disappointed but still not bad for a $75 turbo. Next step over the winter is T67, custom long tube mani and 600whp
300zx single turbo
715rwhp GT42
klattr1
Post by klattr1 »
awesome...good job and nice powerband!
elks240
Post by elks240 »
Damnit I shoulda gone up there yesterday since I called in sick to work.
Are ya gonna put in the new center section ya got?
Did you notice a difference in spool time with the 50/50 mix from your last dyno runs?
veilside180sx
Post by veilside180sx »
Your not making ridiculous amounts of power but it look at how well the powerband holds out. You have tons of power under the curve, must feel great.
JGS Precision
Wastegates, Bypass Valves, KA Turbo Kits
efeezi
Post by efeezi »
veilside-yeah it feels great, hopefully I can get it to the track Friday.
elks-No spool is about the same. So I guess thats good considering the lower CR. And im not gonna put that other wheel in it Im just gonna go T67.
300zx single turbo
715rwhp GT42
halftherotatingmasska
Post by halftherotatingmasska »
at how many rpm's were you making 15psi ? If you don't mind my asking...
Powered by a 57 trim, strapped to a JGS Manifold, and controlled by an AEM EMS. ~ 312 whp 316 ft. lbs. @ 13psi.... DIY is the best way to go!
nissanfanatic
Post by nissanfanatic »
halftherotatingmasska wrote:at how many rpm's were you making 15psi ? If you don't mind my asking...
Looks to be about 4000rpm.
-Cory
2020 Subaru WRX
A long time ago...
Use Linux...
efeezi
Post by efeezi »
Yeah it hits 15psi about 3600-3700 rpms
300zx single turbo
715rwhp GT42
slos14
Post by slos14 »
i cant see the link how much tq did you make .
justin
ka-t on the way
"Horsepower sells cars, torque wins races" - Caroll Shelby
nissanfanatic
slos14 wrote:i cant see the link how much tq did you make .
justin
At 15psi, 328.93 ft/lbs
At 25psi, 384.01ft/lbs
-Cory
2020 Subaru WRX
A long time ago...
Use Linux...
slos14
Post by slos14 »
i may be wrong cause i dont know a whole lot about that turbo but the numbers seem kinda low for 25psi . could some one tell me whats up .
thanks justin
ka-t on the way
ka24detsx
Post by ka24detsx »
^^thats what hes saying is that he found the limit of the turbo which is why the numbers are kind of low because its maxed out...at least thats what i believe hes saying
ah, okay, I wasn't seeing that dyno sheet for some reason, it didn't load before, my bad...
EJ253
Post by EJ253 »
thats a good lookin graph, besides the whole AFR thing before 4k rpms
im diggin it dude, i might be looking at this turbo for when i build my motor
Post by TanManS14 »
EJ253 wrote:thats a good lookin graph, besides the whole AFR thing before 4k rpms
Im sure he wasnt fully on the gas then, hince the lean air fuel...
jpadilla12
Post by jpadilla12 »
Those are nice numbers. I could't believe you brought the turbo for $75. :lol: Can't wait to see the T67 in action strap up on the dyno.
Post by adamky »
...and this is on a stock motor??? (going off of the signature)
