J-Rho's KA-T
J-Rho's KA-T
Here's some shots as I start putting my car together. It won't be running for at least another month or so, so if you're the impatient type looking for a dyno, forget you saw this!
Setup:
Rebuilt '92 KA24DE, .020" overbore, valve job, basically a stock rebuild
Full-Race divded inlet tubular top-mount T3 flanged manifold
Garrett GT3071R with .78/twin-scroll housing
TiAl 44mm wastegate
TiAl 50mm BOV
Spearco liquid-air intercooler
eXcessive Motorsports intake manifold
AMS Fuel system- (Top feed fuel rail, 84lb. injectors, Walbro 255)
Full-Race 3" downpipe, Buddy Club Spec II exhaust
AEM EMS - MAP conversion with 3.5bar AEM MAP sensor, AEM IAT sensor
That's about it for the motor. There's more to the car, I'll be doing another Freshalloy thread on that later.
Oh, guess I should mention this is my first affair with turbos, never played with them before. Should be fun.
Manifold, I think it's the first one off the line for the KA:
On the motor:
Here's how things sat when I started this morning - intake on loose, as I still need to put the injectors in and do a few other things with it. My goal today was to get the intercooler plumbing done and start on the coolant plumbing for the turbo.
A couple of the pipes in place but not cut yet:
A few cuts later, the intercooler is in place. Design goal is minimizing charge volume of intercooler pipes and intercooler itself. Since it'll be getting fed ice cold water, it doesn't have to be as big as a normal air/air.
Another view:
Here's the cooler and pump in the back seat that will be providing the cold water to the IC:
Now the lines for the ice water are connected:
Another view:
With that part done, time to get started on the lines for the turbo's water supply. Assembling the AN lines went pretty well I think, guess I won't know till they see some pressure.
Here are the coolant supply and return lines in. This is as far as I got today:
From the passenger side:
Setup:
TiAl 44mm wastegate
TiAl 50mm BOV
On the motor:
Another view:
Another view:
--SM 240sx in the works...
- sloka-t
are the TB coolant lines of any use anyways? or can i just bypass the TB all together and use the lines that supply the TB with coolant to supply my t25?
ex: use the line that goes into the TB, get a longer one, put it into the turbo. then use the turbos return line into where the TB's return went into...
From Turbonetics - it's the 2-252:KoukiKAT wrote:That's awesome. It should look super sleeper, too. Where'd you get the intercooler?
http://www.turboneticsinc.com/ic_liquidtoair.htm
There is some published data on the relative effectiveness of the liquid/air intercoolers for different liquid and charge air inlet temps:
http://www.racetep.com/tneticatolic.html
I don't know how the performance compares to an air/air, it probably depends on the relative size of each, ambient temps, vehicle speed, etc.
The liquid/air has the advantage that its volume can be relatively small, and because it doesn't have to be in the airstream, the plumbing doesn't have to run all the way to the front of the car. For a DD, you would still need the radiator for the liquid though, which would impede airflow to the main radiator, just as a regular front-mount IC would.
A good V-mount setup is probably a good in-between solution, but the class I race in doesn't allow for any cutting of the bumper beams or radiator support structure, so there wasn't any way for me to do a proper one. Since my runs are relatively short, it'll also allow me to have below-ambient charge air, and keep as much weight as possible off the nose of the car.
The motor that's in the car was already rebuilt from last season, so I'm just going to feed it good gas and see how long it holds up. Cory has had good success making about 420whp with his stock motor, and my goal is only to make about 425-435whp.
I have another KA longblock on a stand that will eventually be rebuilt, but I'm not sure the direction I want to go with it just yet. It would be nice to be able to rev a bit higher and shorten the gearing, so the motor works more between 4000-8000rpm instead of 3000-7000.
And nothing is overkill for the autocrossing I do... While that much power is rarely usable in second gear on the autocross course, for the times it is usable, it's good (and fun!) to have it.
- nissanfanatic
I don't doubt that your motor won't last with a really good tune making that kind of power, that sounds awesome especially with all those nice parts and so more power to you. But I'm thinking that from my experience of super tight autocross, that much power would be kind of pointless.
Also the KA has a really long stroke as it is, so you really shouldn't try to spin that motor too fast, especially since you have a turbo that should give you a very broad and responsive powerband as is. I can't think of an autocross situation when you would be topping out second gear anyway. If you really want more top end power anyway, people seem to be using Crower V2 and V3 cams with really good results, so maybe look into that.
Anyways, your setup is pretty bad ass. The liquid-air intercooler should be perfect for autocross or drag, which your setup seems more geared more towards making big power for drag than autocross. I mean, 84# injectors? What kind of power are you shooting for?
Your input is appreciated White Fastback.White Fastback wrote:I don't doubt that your motor won't last with a really good tune making that kind of power, that sounds awesome especially with all those nice parts and so more power to you. But I'm thinking that from my experience of super tight autocross, that much power would be kind of pointless.
As a bit of background of me, I'm a pretty hardcore autocrosser. In 2006, I won the SCCA Solo2 and ProSolo National Championships for the STS class in my 240. In 2005, I placed third in the National Championships in the Street Modified 2 class, driving a 475whp/475ft-lb Z06. For 2007, I am building up my 240 to run in the Street Modified class.
There are times in autocross, however briefly, where 100% of the power will be usable. In the Z06 I was lucky to spend 1-2 seconds out of 50 at full throttle. There were some runs where I could never use it! While that is frustrating, it makes it that much more rewarding when you can put your foot to the floor.
If this turbo turns out to be too big, I might try running the GT32, the powerband it produces looks very good, and I believe it should work great with my divided Full-Race manifold. My hope is that with twin-scroll and BB technology, relatively high compression, and low-volume charge piping, that I can get acceptable boost response from the 3071R. I hate the feeling of a motor that wheezes and loses torque as it approaches redline, I like one that screams and explodes to the red. Maybe it's my S2000 past that has something to do with that...
The idea to build a higher-revving KA would allow this turbo to spend more time operating with more airflow since it'll be higher in the rev range. This will make it less likely to be off boost when coming out of a slow corner, and at the same time, I could go to a shorter rear gear to improve acceleration further.
The injector size choice was done in an attempt to leave some headroom in case I wanted to do some Time Attack or drag stuff later, where I might want to go with a bigger turbo. They're certainly overkill for the GT3071R but I think the EMS will have the resolution to run them properly - there are plenty of guys running 1000cc injectors in the 400whp range with no problems.
Here's a pic from tonight - fuel system is all plumbed, and the oil supply line is in. Still need to do the oil drain, then attack the vaccum and breather systems.
This car should be pretty BA. Do you ever road course your car?
What are your plans for suspension?
also do you plan to upgrade the cooling system? IE- KOYO Race radiator? and what do you plan to use for fans.
90 HB KA24DET project
Best 1/4mile so far 12.56@114
My Cardomain:
http://www.cardomain.com/id/90_240SX_KA24DET
My Cardomain:
Haven't tracked this car yet, though I do have a fair bit of experience on track - my 1:27.9 I think is still the fastest S2000 laptime at Willow Springs.
This car is being built mainly for autocross at this time, so the braking and cooling systems are not going to be able to handle track-type usage.
Because in autocross we spend most of the time either not moving, or moving slowly, one of the thicker multi-core radiators isn't really the way to go. I'll be getting a pair of low-profile fans, and counting on them, and lots of time spent idling, to keep the car cool.
The STS suspension buildup and more info about the rest of the car is here:
http://forums2.freshalloy.com/showthrea ... t&t=139581
I'll be starting a similar thread soon to detail the next wave of mods, in addition to the motor, that is being done for the Street Modified class.
For instance, here is a rear wheel test fitment. 18x12.5" to fit a 315/30-18 Hoosier A6-
Hey Brian,
I have a big post I'm putting together to detail the whole SM build on Freshalloy, don't you worry. Just thought I'd share some of the motor-related stuff here, since it's not likely to be found and read by my competition.
I got the flares from Raceonusa.com, they're not too far away from me, so I picked them up, along with a vented FRP hood.
Are you keeping the super hicas system or eliminating it?
those are some big rims and tires
My Cardomain:
My Cardomain:
- nissanfanatic
Yep, they are from CCW, aka Complete Custom Wheel. They are very popular because they're relatively lightweight, relatively inexpensive, and look pretty good. Because they're custom 3-piece, they can be made in any size you want, and if you later want to adjust the size (or need to repair part of a wheel) you can just change out a rim half, which is not that expensive. CCW's service is great too.
- nissanfanatic
