New Cut Bumper Pics
New Cut Bumper Pics
Well I decided to cut my bumper today to get some more airflow to the IC and rad and well here are the results.
You can clearly see theres lots of room for cold air eh....
2JZGE NA-T -SOLD
10.3@131 27psi
- xtearsfallforeverx
Well, nothing like having the wife looking over my shoulder right when I opened this...
Haha, looks good!
Haha, looks good!
1995 240sx SE KA-T
50k miles
FOR SALE? Make an offer over $8k
AMS GT32, JGS mani, 555's,
AEM Truboost, oil pressure gauge and wideband, GReddy RS bov
Tial wg, Walbro, JRC FMIC
Calum RealTime ECU
50k miles
Calum RealTime ECU
- Biggamehitt
why not? how can you screw up cutting a bumper?nis240 wrote:Mt cut bumper definently doesnt look as good as that.
what I want to see is someone glass a liped edje on the cut part of the bumper to kind of match the stock lip that goes in.. you know what I mean, to make it that stock professional look.
now get on that right away and stop staring at her ass
- Forum Moderator
This looks awesome ... i like the way you cut it ... wheels look dope as well ...
Lance ~ what does your sticker say?? ~ and why not leave your bumper like that .. i think it looks mean as hell ...
It says NODRFT, as in http://www.nodrft.com
I'm installing an FC oil cooler to help out on those hot track days, and the oil cooler is 22x4.5x2. Being that size I've only found one place to mount it. Right behind the front bumper support. It needs some sort of airflow. My car is more function over form.
the oil cooler
the oil cooler
Lance, don't cut your bumper! It looks real good the way it is.
Have you thought of doing some simple ducting to divert air to the oil cooler?
Also, can you PM me with some pics of your oil cooler set-up (when it's finished)? I'm considering doing it this summer and I'm trying to see how other people have done it.
Thanks!
[/end threadjack]
Thanks!
[/end threadjack]
1995 240sx SE KA-T
50k miles
Calum RealTime ECU
50k miles
Calum RealTime ECU
Well went for a cruise last night and cruise temps were rock solid at 167. They would normally fluctuate a few degrees up and down. It wasnt until I was sitting in the drive thru that the temps started to go up a bit. So it does have its advantages. The disadvantages is that the intercooler is more exposed so I get a lot more looks at the front end rather than the wheels. And sitting in the left turning lane, all the dumbs kids coming my way see it and start to floor their sunfires and cobalts like they are fast. ....silly ricers.
2JZGE NA-T -SOLD
10.3@131 27psi
damn lance, you cut perfect right angles. Looks good, hopefully this will help keep temps down on our track days. Happen to notice any difference in oil capacity with this setup? Also post pics of your line routing.......thanks ngr
'my drinking team has a racing problem'
13.213 @ 108.72mph gt32- .6bar/ 13.81@ 102.5mph stock z33
kings blend-I assumed it would help temps a lot.
MyRedS14- there's no way to duct air to it, being that the S13 chuki bumper is probably the most restrictive compared to the other OEM bumpers. It would be perfect to fit behind a grill but I have none. Plus having extra air flow to the raidator would be benificial. Keep in mind this car sees an extreme amount of abuse, between auto-x, drag, drifting, and road racing. I'm looking for the most efficient solution, my bumpers just gonna have to take one for the team.
Rob- that's just a little paint work, meeting Kim at the shop to do some cutting, am still waiting on the block sandwich adaptor and relocation. From some measurements of the oil cooler and lines, oil capacity should be increased by 1.5qts, or close to it.
- nissanfanatic
- 1wheelwonder
I'll post pics of mine, it should be done in a day or two. Mine will look like my intercooler but it is actually the oil cooler sitting on top of the intercooler. The intercooler stops where the opening stops.
Kings Blend- I would try to add some ducting around the cut-out area meeting up with the intercooler. You don't want the air to hit it and flow around it, force it through no matter if she says nooo.....uuuummmmmm....I mean
