Z32 maf install + wiring info
- rob 2fast4u
well I decided to do a small write up since I was at it.
This is how to wire in a z32 maf ( n62 ) into the factory s13 wiring harness
this is the stock conector :
and the z32:
cut the harness off the old connector and start soldering the wires from the z32 connector together. Make sure you get good penetration with the solder and shrink wrap it when your done.
Here is a diagram that I made. From searching on the forum Im almost positive this is how you wire the two together if not PLEASE TELL ME !!!!! and I will make the changes.
and the z32:
fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
has t3/t04e 60trim need a bigger one for 25psi ???? s366 maybe
custom exh & intake manifolds
ebay ssqv bov
2.5"hotpipe, 3"coldpipe, Blow through MAF
AEM FIC,Zeitronix wideband, z32 maf
Bosch 1000cc inj, Twin walbro's, -8AN feed line,.... and lots more
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
i hope for ur sake u soldered that stuff and heat shrunk tubing over that. if it gets moisture in there ur ****.
currently n/a.
currently n/a.
- rob 2fast4u
ya I did and I even lengthend the sheilded wire right up to the conector.
fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
its nice to here that someone's doin **** the right way.good job.
currently n/a.
currently n/a.
- rob 2fast4u
haha thanks man... ah just wondering, in the background you can see the engine harness ... I am taking all my idle control off the intake and all the emissions is already off but to make the harness look abit cleaner can I just cut off the wires I dont need and tape them up or something like that so there not in the way ?
fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
id imagine, as long as their to somthing thats not gonna b hooked up.
currently n/a.
currently n/a.
Quick question.
Some diagrams show both grounds going to the wiring harness and others (like yours) show one going to the chasis. Whats the worse that would happen if you dont have one going to the chasis? Im guessing it would just cause your car to stumble and **** at high rpms.
Also, what gauge wire did you use to connect to the chasis?
'91 240sx hatch- s14 block, s13 head, s14 intake/s13 exhaust cams, Supertech 8.6:1 pistons, eagle H-beam rods, arp hardware, jgs starter kit (T3/T04E 50 trim .63 A/R), tomei 740's, ebay i.c. kit, HKS SSQV, 3" piping tubo back, efi specialists ecu, walbro 255, safc 2, plx m-300, knocklite
'93 240sx coupe(DD)-aem intake!!!
SR_what? wrote:Quick question.
I connected both the grounds together and connected them to the wiring harness ground. No problems yet.
i did the same **** , not a prob.
currently n/a.
currently n/a.
^^^ Cool. Thats what i was hopin to hear. I already wired mine that way and just wanted some reasurrance. Thanks dudes.
- rob 2fast4u
Ya theres not a really a YOU SHOULD DO THIS when wiring the two ground wires, some people take one ground the the chassis some others just attach both together to the harness. I guess it depends on your preference, I have "heard" or "read" that some people had issues with wiring them in together but so far adamky said he's not having any issues yet so looks to be alright
fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
- hotrodstu77
well most of us here are/will be using the z32 maf because it flows more and it works with tuned ECUs but your ecu must be tuned for it. cant do it with a stocker. and i hope this gets locked in the how to section. its very helpfull
Crazy about the KA
mod list so far:cold air, clutchmasters twin friction, nismo clutch master, short throw, VLSD, 3" ebay exhuast, SSAC mani, .42/.48 garret t3, FMIC, Tein prings, Tokico Blue struts
The Nissan 240sx: It's a lot of sports car, but you can handle it.
Canadians are born drifters!
Dodge Cummins vs. Ford Powerstroke= I'd rather be cummin then strokin
- hotrodstu77
thts what i did. always good to have one
Crazy about the KA
- rob 2fast4u
^ Alright thanks for clearing that up, Its to bad its freezing out here... or else I would have my car running by now. Theres soo much work ahead of me....
And also thanks to everyone for the reply's!!!!!!!!
fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
ebay ssqv bov
Hey anyone able to help i wired my n62 from top of maf to top of stock plug is that right
Does white go to white or am i wrong or does black/grey go to white!!! i followed
one of the how to's and now im not sure the hwo to was right i checked and double
checked to see if the plugs on the pic's he posted were the same. my car idls like crap and
smokes out of the exhaust real bad ( its not the turbo ) let me know thx.
ok nvm! here is for the new people that dont know how to wire i'll make it clear white goes to white and black/white goes to black/white and the two in the middle go to ground on the s14 wire ok there you have it. I wired it wrong due to someone's post that was incorrect so my car idled like sht but i didnt damage it lucky me thanks though, but now it runs fine.
Sorry to revive this. I know the diagram at the top is pretty self-explanatory, but I have a question since my car runs like ass and I think my MAF may have something to do with it. When wiring the Z32 MAF in, you connect white to white...striped to striped...then I connected the orange to the black...and grounded the Z32 black. That is correct right? I've been having problems since my install soI want to narrow down all the possible problems. And it's suppose to read 1.3 volts @ idle? Is this all correct?
*mike*
*mike*
- Jordan Gladman
Exact same as this one.
For anyone interested interested in "salvaging" their OEM harness and not cutting off their stock MAF plug, if you have an extra TPS sensor, you can chop it up and use the female receptical to make an adapter cable to go from the Z32 to your OEM harness without having to cut it. I did mine this way and it saves you the trouble of having to ever rewire to go back to stock for whatever reason.
